Hey all,
I'm not sure if this should go here or into the design forum but I figured hey, I made sawdust so the build is underway. I have been a lurker for about 2 years other than posting in the vintage equipment area (thank you guys so much for that particular illness). My design is based on the superlaggera with some modifications. I plan to have my nearly 5 year old sleep across my wife and my feet on a cot...shelf...thingy. Having the boy sleeping in the cabin with us made it so that we needed to go with a 5x9. The superlaggera design lends itself to doing this easily because the roof is flat in one area so i only have to stretch the design in that area. The lower front of the design has a 11" radius and i think that it is a bit too tight so I decided to extend the 30" upper radius. my plan is to frame in poplar or pine or some combination therein, and skin in marine plywood for the exterior and prefinished maple on the interior and then wrap everything in aluminum. Today I got some 1/4 ply to make my template. Here is a Pic of today's work:
The white tape is where the frame and floor will be, the orange is for the mattress, the blue is for cabinets and the green is the door. I rough cut the template with a jigsaw and then I crept up to the line using a block plane and a sanding block.
I hope you guys like it but am totally up for comments and criticisms.
-James Porter
