I had the day off today so I got some more done today:
I got the outer frame done for both walls, this included, cutting all of the pieces to size, clamping them to the template to trace the outline of the template, rough cutting the traced portion out on the band saw, re- assembling the parts back on the template, gluing and pocket screwing all pieces back together, running the router around the outer edge using the template as a guide, and lastly filling all of the pocket holes (I don't like the idea of having voids in the wall structure). I managed to get these tasks completed today with varying degrees of success. I had some pretty bad chipping along the top of one of the walls so that is being filled as well. I also was able to put most of the interior framing in one of the walls.
- P3200937.JPG (47.12 KiB) Viewed 4106 times
The pocket holes were filled with a combination of tite-bond III and sawdust.
- P3200939.JPG (35.93 KiB) Viewed 4106 times
For various reasons (read as machine operator error)the walls didn't come out perfect. I left off tonight with the two walls clamped together so that I can make them match.
- P3200938.JPG (39.58 KiB) Viewed 4106 times
