So I am at the point in the build process where I need to consider what skinning method to use. Originally the plan was to use a filler for the screw holes and gaps. Then apply a primer and use an epoxy based boat paint for a water tight seal (maybe glass tape on the seems too). I have questioned this method a bit and thought maybe a light 4oz layer of fiberglass under the paint would give me piece of mind. Now I am seriously looking at aluminum. I originally shied away from this for two reasons. First, I thought the cost would be prohibitive compared to the other methods but I am noticing that it isn't that much more. (epoxy paint it expensive) Second, I wasn't sure if I could tackle the job alone. However, after lots of reading it seems floating the aluminum seems to be the way to go which makes it doable.
With all that said, do you guys believe the epoxy paint with fiberglass tape on the seems provide years of durability or should I invest in aluminum?
