Nano Cub
Re: Nano Cub
Postby Micro469 » Mon Oct 28, 2013 8:42 pm
bump............... :thinking:
John
Micro469
Images: 382
Re: Nano Cub
Postby Micro469 » Mon Nov 04, 2013 11:51 pm
mikeschn wrote:
Micro469 wrote:I presume that's a 4x8 piece of plywood. What thickness is it....and how much does it weigh? and after you routed it out.....what's the final weight??
John,
Yes, it's a 4x8 1/2" plywood. I"ll run down and check the weight in a bit.
Thinking about another one are you?
How long is "a bit" ? :roll:
John
Micro469
Images: 382
Re: Nano Cub
Postby mgb4tim » Tue Nov 05, 2013 3:46 pm
Just general CNC questions - is the surface that the material to be cut sits on sacrificial?
And, how do you keep things from moving, like that door frame, when ti's nearly free?
mgb4tim
Re: Nano Cub
Postby mikeschn » Wed Nov 06, 2013 5:13 pm
Hey John,
The frame as you see it weighs about 11 pounds...
Plywood typically weighs about 25 pounds per 1/4" of thickness, so the starting weight was probably around 50 pounds.
As for how long is a "bit"? Usually not long unless you forget about it, then it can be years and years!!! :lol:
John,
Re: Nano Cub
Postby Micro469 » Wed Nov 06, 2013 9:52 pm
Thanks Mike...... :thumbsup:
John
Micro469
Images: 382
Re: Nano Cub
Postby GPW » Thu Nov 07, 2013 4:31 am
That’s Nice and Light !!!! 8) :thumbsup: :applause:
Re: Nano Cub
Postby mikeschn » Thu Nov 07, 2013 5:05 pm
Yes, that's a sacrificial board, and my cnc software lets me put tabs on the part so it doesn't go flying when it's cut out!
mgb4tim wrote:Just general CNC questions - is the surface that the material to be cut sits on sacrificial?
Re: Nano Cub
Postby GPW » Fri Nov 08, 2013 6:55 am
Mike , would I be wrong in thinking if you cut out a foam sheet (3/4") on the CNC, same program, the foam dropouts would fit exact in the plywood cutouts...??? :thinking:
Re: Nano Cub
Postby KCStudly » Fri Nov 08, 2013 7:40 am
You would have to allow for the cutter diameter by following the other side of the line, but since the hard part is getting the line in there in the first place, that should be relatively easy. :D
Re: Nano Cub
Postby mikeschn » Fri Nov 08, 2013 4:34 pm
KC is right, your bit would have to be on the other side of the line. But the short answer is, yes, you can use the same geometry to generate your toolpath.
Re: Nano Cub
Postby GPW » Sat Nov 09, 2013 6:55 am
Oops !!! Forgot about the dia. of the bit ... :duh:
Re: Nano Cub
Postby 123jay » Sat Nov 09, 2013 10:32 am
Do you have any post on your cnc set up
401/2"X 48" open tailgate bolt together army kit around $450.00
If the world did not suck ,you fall off!
123jay
Re: Nano Cub
Postby Corwin C » Sun Nov 10, 2013 9:05 pm
You should be able to just change the bit offset from left to right or right to left depending on how it's coded.
Corwin
Image Image Image
-- myself
Corwin C
Images: 78
Re: Nano Cub
Postby GPW » Thu Nov 14, 2013 6:55 am
just thinking ... This frame filled with foam ,a roof, a layer of 3/4" foam on the outside (or whatever) and a covering (canvas, fiberglass, etc. ...) Instant TD !!! :D ... Light, insulated, and the wood is encapsulated for protection ... :thinking:
Mike , I don’t know if this applies, but could you cut recesses/pockets in the frame to accept cross members ...1” X 2” s for the roof ... ? Maybe 3/4 the depth of the ply... so they wouldn’t show on the outside ... ? Would make assembly Quick work ...
Re: Nano Cub
Postby mikeschn » Wed Dec 04, 2013 6:30 pm
That sounds pretty good Glenn.
How would we protect the wood in the galley area and in the hatch?
GPW wrote:just thinking ... This frame filled with foam ,a roof, a layer of 3/4" foam on the outside (or whatever) and a covering (canvas, fiberglass, etc. ...) Instant TD !!! :D ... Light, insulated, and the wood is encapsulated for protection ... :thinking:
