mikeschn wrote:Micro469 wrote:I presume that's a 4x8 piece of plywood. What thickness is it....and how much does it weigh? and after you routed it out.....what's the final weight??
John,
Yes, it's a 4x8 1/2" plywood. I"ll run down and check the weight in a bit.
Thinking about another one are you?
John,
mgb4tim wrote:Just general CNC questions - is the surface that the material to be cut sits on sacrificial?
And, how do you keep things from moving, like that door frame, when ti's nearly free?
GPW wrote:just thinking ... This frame filled with foam ,a roof, a layer of 3/4" foam on the outside (or whatever) and a covering (canvas, fiberglass, etc. ...) Instant TD !!!... Light, insulated, and the wood is encapsulated for protection ...
Mike , I don’t know if this applies, but could you cut recesses/pockets in the frame to accept cross members ...1” X 2” s for the roof ... ? Maybe 3/4 the depth of the ply... so they wouldn’t show on the outside ... ? Would make assembly Quick work ...
