Whatcha do on your build today?
Re: Whatcha do on your build today?
Postby Ron Dickey » Sun Oct 26, 2014 11:16 pm
i painted primer on the bottom of the cabinet that is above our heads when we sleep, next step is to paint it white blue, then stain the wood walls and install the reading lights.
When I started this project, I tried to do it in several months and made several mistakes. So now I have slowed way down to correct them and make a better trailer.
ron
173882......173887
Ron Dickey
Images: 787
Postby KennethW » Sun Nov 02, 2014 8:36 pm
I got a counter extension installed. fold up,slide out and put stick under. Click on pic's to inlarge
125949folded up
125953Up and ready
I also got a 19" 12 volt TV installed with a home made antenna. (search for a coat hanger antenna)
125947
125948Walmart 19" TV has a wall wart with a 12 Volt output. I spliced in a 12 volt plug
The outlet cover is to lead the antenna wire in side
125954cooler out,stove ready and game on the tube
KennethW
Images: 82
Postby nevadatear » Sun Nov 02, 2014 8:41 pm
Installed new door weatherstrip, winterized and stored away in garage. :). Waiting until spring.
nevadatear
Images: 171
Postby Glenn Butcher » Sun Nov 02, 2014 8:55 pm
I lengthen-ed my tongue. On the trailer...
Glenn Butcher
Images: 16
Postby working on it » Sun Nov 02, 2014 9:27 pm
Glenn Butcher wrote:I lengthen-ed my tongue. On the trailer...
I've got that beat...I drilled two 1/2" diameter holes in my tongue
...also on my trailer. haha Actually, I was concerned about the chain attachment point on my tongue, a single link welded under the tongue. Perhaps it was sufficient when the trailer was under 500 lbs, but I worried about it tearing loose with the now 1538 lbs (down from 1775 lbs) trailer. My coupler is very well welded to the tongue (3 x 3 x .1875 square tube), so I figured that I could use the two holes in the coupler's sides (for bolt-on purposes) for attaching the chains. I now have them attached via two 1/2" Grade 8 bolts/nuts/lock washers/flat washers, and tied to the tongue further back with u-bolts. Now I'm pretty sure that the three-point attachment of each safety chain will be quite sufficient. No pics yet.
173193172890148599
working on it
Images: 457
Postby len19070 » Mon Nov 03, 2014 6:10 am
I did something very important on my 13' Scotty HiLander build this weekend.
With the sale of my RT Tear,
I Paid off all my Bills on my Scotty!
Happy Trails
Len
len19070
Images: 24
Postby Vedette » Thu Nov 27, 2014 1:30 am
Went out and brushed 6" of wet snow off of "Kermit" :x
It is still outside! :cry:
126612126611
Good Roads
Brian & Sandi
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Postby canned o minimum » Thu Nov 27, 2014 10:20 pm
So if I'm only "remodelin" the interior, izzat still considered a "build" ? Cause I'm now workin on the galley since I got the "cabin" insulated with 3/4 inch foam insulation, and skinned with Red Oak panelin.She's a 1946 that was never planned to be "finished" on the interior,but I had other plans since I plan to use it year round.
canned o minimum
Postby Modstock » Fri Nov 28, 2014 1:25 am
len19070 wrote:I did something very important on my 13' Scotty HiLander build this weekend.
Len
Im starting to like RT's do ya have any build pics ?
Modstock
Postby len19070 » Fri Nov 28, 2014 8:12 am
Len
Sure, http://s26.photobucket.com/user/len1907 ... t=2&page=1
This RT design was one of the most comfortable trailers I've ever built. With the dropped floor at the rear you could sit on the end of the bed and put your shoes (that could be stored inside) on and at night it was very easy to use the "Coffee Can" from that same position.
Happy Trails
Len
len19070
Images: 24
Postby bobhenry » Mon Dec 22, 2014 6:57 am
Were are these morons coming from ? :stompspam: :stompspam: :stompspam:
Stomp it out quick . This is the 3rd one I have found in the 5 minutes I have been on.
Admin's HELP HELP HELP !
Postby felixx » Fri Jan 02, 2015 5:01 am
Ordered trailer hardware this morning
Won two tyres for the rims I have for $22 each on trademe
Getting close to start time
:D
felixx
Images: 22
Postby Roly Nelson » Tue Jan 06, 2015 5:58 pm
Pullled my 450 lb woody teardrop out of the workshop and into the enclosed storage area, ready for sanding and varnish. Gotta get this show on the road, now that the 10 inches of snow has melted in my So Calif town.
:? Roly
Roly Nelson
L'il Ol' Woody Builder
Postby KCStudly » Tue Jan 06, 2015 7:23 pm
Nuthin'. :roll: :NC :oops:
Postby camper4life » Wed Jan 07, 2015 12:13 am
Finally mounted my roof rack brackets and put up my new curtains that I made this past weekend
127640127641127642
camper4life
Images: 39
