Sealing floor
Sealing floor
Postby Da'engineer » Mon Apr 13, 2015 12:59 am
I just got done building and mounting my floor.
Now comes the phase of sealing the wood.
I was thinking about using an epoxy resin then painting it. But I was curious if there was any better routes? Or any experience to speak-up about?
Da'engineer
Re: Sealing floor
Postby S. Heisley » Mon Apr 13, 2015 11:41 am
The problem with using epoxy and then painting it is that, with some epoxies, you have to wait a while before you paint it because the epoxy can off-gas, causing a loosening of the paint. IMO, epoxy is always the best to use to seal your wood; however, check with your epoxy manufacturer to see how long you should wait before covering it with paint.
For the underside of the deck, most people simply spread on the black roofing tar-gunk, which seems to work very well. I used epoxy and let it sit quite a while, as I worked on the walls, etc. Then, I sprayed on undercarriage spray (another black gunk) that I purchased from the auto parts store.
Re: Sealing floor
Postby KCStudly » Mon Apr 13, 2015 7:03 pm
Don't forget the amine blush. Most epoxies exude an amine blush as part of the curing process. After a hard cure be sure to wash the amine blush off before sanding, filling, or any other operation. The amine blush is sort of a waxy like substance. It's okay to do wet layups, but after a hard set you have to get rid of it. Washes off with water.
Re: Sealing floor
Postby S. Heisley » Mon Apr 13, 2015 7:49 pm
KCStudly wrote:Don't forget the amine blush. Most epoxies exude an amine blush as part of the curing process. After a hard cure be sure to wash the amine blush off before sanding, filling, or any other operation. The amine blush is sort of a waxy like substance. It's okay to do wet layups, but after a hard set you have to get rid of it. Washes off with water.
:thumbsup: Thanks, KC.
Re: Sealing floor
Postby Da'engineer » Mon Apr 13, 2015 8:52 pm
Thanks the both of you for the solid advice. You've both been so much help with this build! Now i just have to find a good cheap epoxy.
Da'engineer
Re: Sealing floor
Postby Da'engineer » Tue Apr 14, 2015 11:25 pm
After weighting out prices and such I was thinking about going with this
http://www.acehardware.com/product/index.jsp?productId=1274691
Here is the MSDS for it http://www.modernmasters.com/images/documents/tds/Bulls_eye_1-2-3_by_Zinsser_TDS.pdf
I was planning to put two coats down then coat it with the undercarriage spray that they use with cars and trucks
What do you think?
Da'engineer
Re: Sealing floor
Postby S. Heisley » Wed Apr 15, 2015 7:54 pm
Da'engineer wrote:After weighting out prices and such I was thinking about going with this
What do you think?
:thinking: I'd call the manufacturer of that primer and explain how you plan to use it and ask them what they think. They should know their product. The auto undercarriage spray has definitely worked for some of us.
Re: Sealing floor
Postby tony.latham » Wed Apr 15, 2015 9:17 pm
It seems to me you should contact whoever makes that spray and ask them what primer to use.
Me? I'm an epoxy guy, but that Henry's black goo has been working for fifty years.
T
