I just got done building and mounting my floor.
Now comes the phase of sealing the wood.
I was thinking about using an epoxy resin then painting it. But I was curious if there was any better routes? Or any experience to speak-up about?
KCStudly wrote:Don't forget the amine blush. Most epoxies exude an amine blush as part of the curing process. After a hard cure be sure to wash the amine blush off before sanding, filling, or any other operation. The amine blush is sort of a waxy like substance. It's okay to do wet layups, but after a hard set you have to get rid of it. Washes off with water.
Da'engineer wrote:After weighting out prices and such I was thinking about going with this
http://www.acehardware.com/product/index.jsp?productId=1274691
Here is the MSDS for it http://www.modernmasters.com/images/documents/tds/Bulls_eye_1-2-3_by_Zinsser_TDS.pdf
I was planning to put two coats down then coat it with the undercarriage spray that they use with cars and trucks
What do you think?
