CCC Woody - tent trailer
Postby Russ B » Thu Aug 23, 2007 12:26 pm
A TJ is a 1997-2006 model Jeep Wrangler.
Whoomah!
Russ B
Postby Cliffmeister2000 » Thu Aug 23, 2007 12:56 pm
Russ B says:
Well, there you go! Thanks, Russ! I'll bet it has more power than my 1.6l 1991 Geo Tracker!
Cliff
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
My Teardrop build pictures
Cliffmeister2000
Titanium Donating Member
Images: 157
Postby Russ B » Thu Aug 23, 2007 1:20 pm
120-147hp for the 4-cylinder version, depending what year it is.
Whoomah!
Russ B
Postby Cliffmeister2000 » Thu Aug 23, 2007 1:38 pm
My Tracker is 80 hp, but I really don't intend to use it as a tow vehicle. My Honda CR-V is supposed to be 160 hp, and it towed the one you see on my Avatar just fine. Gas mileage did drop from 23 mpg to about 18 mpg though. Small price to pay!
Cliff
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
Cliffmeister2000
Images: 157
Postby asianflava » Thu Aug 23, 2007 2:57 pm
TJ = Tomorrow's Jeep
YJ = Yesterday's Jeep
CJ = Classic Jeep
asianflava
Postby jagular7 » Fri Aug 24, 2007 8:29 am
Cliffmeister2000 wrote:My Tracker is 80 hp, but I really don't intend to use it as a tow vehicle. My Honda CR-V is supposed to be 160 hp, and it towed the one you see on my Avatar just fine. Gas mileage did drop from 23 mpg to about 18 mpg though. Small price to pay!
Cliff
And my stock TJ got only 15mpg. Mod'd it gets 13mpg, heading down hill with a tailwind.
Here is another configuration - Aerowagon to ponder.
Mike
Jagular
Lenexa, KS
jagular7
moded jeep
Postby Jeeper92 » Fri Aug 24, 2007 10:02 am
TJ-Tough Jeep
YJ-Yuppy Jeep
CJ-Classic jeep
I have a 2001 tj and it can tow 2000, tounge weight of 200
Mine is lkifted 3 inches and has 33 inch tires on it, I lost a ton of gas mileage when i lifted it, but i installed a throttle spacer and cold air intake and im back to 16 mpg
I plan on doing a catback and a computer chip, after all that i should be up to about 18,19 mpg, which isnt that bad
Jeeper92
Postby Cliffmeister2000 » Fri Aug 24, 2007 11:27 am
Jagular7 says:
I always wanted a Jeep, and the reason isn't necessarily performance or status, it's PARTS! Without eBay, my 1991 Tracker would be rusting away in the dump by now. There are very few parts available. It seems, however, that Jeep parts have an endless supply.
Cliff
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
Cliffmeister2000
Images: 157
Postby schaney » Fri Aug 24, 2007 5:42 pm
Yes a 4cyl TJ has a 2K rating, but with 1400 lbs of tent trailer behind it, I would get 9-14 mpg, has horrible road manners and needed 2nd/3rd gear for mountain passes over 8000'
I like Let's Go Aero's gear hauling trailers. What I don't like about their Gear Wagon tent concepts is you have to take overthing out of the trailer for sleeping. I prefer putting tents on top of the trailer. I can pull into a camp site, open my tent and be in bed in a few minutes, no unloading.
Scott
Camping the "Compact Way"
schaney
Images: 262
Postby jagular7 » Fri Aug 24, 2007 11:15 pm
Cliffmeister2000 wrote:Jagular7 says:
Cliff
There are plenty of parts for the Trackers. Have you gotten together with any other Zuki owners? They may be a lot of Sami owners, but there are a lot of Tracker/Sidekick (Trackick) owners out there. There is lots of support also.
Have you checked out other Zuki forums? Pirate4x4, Zukiworld, Zuwharrie, Zookpower (Can.), zuknation, etc are not just about Sami's.
Sort of like this place. Lots of various forms of one type of product, then some variations that lead to similar and disimilar traits of a sleeper box on wheels. :thinking:
Mike
Jagular
Lenexa, KS
jagular7
Re: moded jeep
Postby jagular7 » Fri Aug 24, 2007 11:21 pm
Jeeper92 wrote:TJ-Tough Jeep
YJ-Yuppy Jeep
CJ-Classic jeep
Mine is lifted 3 inches and has 33 inch tires on it, I lost a ton of gas mileage when i lifted it, but i installed a throttle spacer and cold air intake and im back to 16 mpg
May I suggest that you also look into changing to a lower set of gears (higher numerically) since you added larger tires. That's one of the biggest disappointments when spending money to get the larger tires installed. Not only do the tires cost, wheels, and suspension mods cost just as well. Going too much in difference in tire sizes, basically dis-performs the engine and driveline effeciency.
I've got 4.88s installed and when it was opened, added lockers. Currently running on 34's, but will be stepping up to 36's when there wear out.
Mike
Jagular
Lenexa, KS
jagular7
Postby jagular7 » Fri Aug 24, 2007 11:38 pm
schaney wrote:Yes a 4cyl TJ has a 2K rating, but with 1400 lbs of tent trailer behind it, I would get 9-14 mpg, has horrible road manners and needed 2nd/3rd gear for mountain passes over 8000'
Its also the same with many TDs. You place a lot on the bed to bring with you that it takes some time to set up or put to aside just to lay down. I'd like a camper, I'm working on it, that is hardside, walkin-able and has a sleep area ready to go. Insulated hardside minimizes noise when sleeping during transit. Having something ready to go is simply, park-n-sleep scenario. Depending on the setup, it could be pleasing as well as restful. I haven't traveled very far with the TJ, but did a couple multiple state trips with my Bronco and 16' Scamp. It was pleasing to do so, especially with the 2 kids (little back then) and a wife.
Found some more pics of the Crossbow.
Mike
Jagular
Lenexa, KS
jagular7
2000 lbs
Postby Jeeper92 » Sat Aug 25, 2007 7:47 am
with the 4 cyl, i have the 6 i m wondering if mine might not be a little bit moer, i never got an owners manual and have been searching for a site to get the info
Jeeper92
Postby Cliffmeister2000 » Sat Aug 25, 2007 8:27 am
Jagular7 says:
I just found Zookpower the other day! Thanks for the tips on the otherS!
Cliff
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
Cliffmeister2000
Images: 157
Postby schaney » Sat Aug 25, 2007 4:03 pm
If I remember correctly the 4 & 6 cyl TJ's had the same tow rating because of their short wheel base.
The Crossbow trailer is nice by $22-23K USD is out of my price range, and don't forget the $5-6K to ship it over.
Oryx has a similar trailer that's squarer, has a cool separate room (rooftop tent) feature, and it's only $17-18K USD.
Scott
schaney
Images: 262
