So, in the same spirit of making my own teardrop, I'll make a pair of pontoons.
I didn't get pictures of the block, but there was a huge billet of foam that was pretty battered at work. It's 2 pound per cubic foot, and measured 8 feet by 4 feet by 3 feet. They were throwing it in the dumpster when I asked if I could have it.
I made a wire cutter with a couple of pool cues and a pine board. A battery charger provided the power.
Using the edge of a length of ply for a guide on each side, I sliced the foam into 12" by 14" logs.
Here's an idea of how battered the billet was.
I had to join chunks to make four 8' by 12" by 14" blanks
I sliced the enda of the blanks at 35*
Then I pointed the ends at 30*
A chamfer on the bottom edges completes the shaping of the pontoons
To hold the pontoons to the deck, I decided on inlaid nutplates and eye bolts. I sliced out strips for the ply nutplate mounts.
Jig for cutting grooves.
There are three nutplate grooves on each pontoon. Here's a strip test fit in place.
The nutplates are a 1/2-13 nut welded to a flat washer. buying eyebolts would have been about $5.00 each, so I welded a lock washer to the head of a bolt to make my own.
Here's a shot of the four pontoons waiting for the nutplate mounts. I did glue a strip of pine on all the pointed ends to take the abuse of running up on shore, etc.
I glued (with gorilla glue) and used three screws to attach the nutplates to the inlay strip.
Twelve nutplate assemblies that will be glued in place soon. Wood end strip is visible on the pontoon behind the sawhorses.
Sam
