New 6 x 10 travel trailer build under way
Re: Preliminary plans for a new teardrop style travel traile
Postby KCStudly » Sat Mar 09, 2013 8:52 am
It is gooey and pliable so that it can remain flexible with heating and cooling cycles. Not many people see the top of a full size RV. Also, I fear that the aluminum dust will not appear even; there will be swirls, roller/brush marks and sags.
I'm with Norm on this one. I would pick something else, like boat hull paint (although I realize that may be more $$).
Woodbutcher (Steve) did a great job with marine vinyl on the roof of his Slowmobile.
Postby Irving » Sat Mar 09, 2013 12:24 pm
KCStudly wrote:It is gooey and pliable so that it can remain flexible with heating and cooling cycles. Not many people see the top of a full size RV. Also, I fear that the aluminum dust will not appear even; there will be swirls, roller/brush marks and sags.
Are you referring to some type of marine vinyl paint? Or a solid sheet of vinyl material?
Irving
Postby KCStudly » Sat Mar 09, 2013 1:49 pm
No, the marine vinyl is the fabric backed flexible stuff used for seat cushions and Tonneau covers; like they used to put on car roof tops.
The hull paint I am less familiar with, but I think it is a two part epoxy.
Postby mezmo » Sat Mar 09, 2013 10:54 pm
Hi Irving,
I've owned a couple mobile homes in the past and coated the roofs
every other year or so with the aluminum roof coating, so I have
plenty of experience with it. This was before they came out with
the new white coatings that are now available and which are more
expensive. I do not have experience with them, but I wouldn't consider
using them either.
KC said it well:
"It is gooey and pliable so that it can remain flexible with heating and cooling cycles. Not many people see the top of a full size RV. Also, I fear that the aluminum dust will not appear even; there will be swirls, roller/brush marks and sags"
It will also ruin your clothes if you rub against it as it will easily rub off.
It is a "coating", not a "finish". It doesn't get hard like paint or other products
that are meant to be used as an exterior wall finish. You are asking for a mess if you
use it as an exterior 'finish' for you walls or roof that is easily accessible to touch.
Besides, it'd make any TTT ugly looking if you used it, and I'm sure you'd want
all of your efforts in building the TTT to look the best thay can.
Cheers,
Norm/mezmo
mezmo
Images: 194
Postby Irving » Tue Mar 12, 2013 7:21 pm
Irving
Postby mezmo » Tue Mar 12, 2013 8:21 pm
No direct experience with them - But:
The first says it is asphalt based 'with rubber added' [paraphrasing].
It'd have the same problems the 'aluminum Mobile Home roof coat' does.
I'd stay away from it.
The second one, the 'Henry's', has been mentioned/discussed on here, but I can't
recall on which thread. You'll have to search that out. The info provided doesn't
list wood - in any of its forms - as a surface that it is recommended it be used on.
So draw your own conlusions on that. It might work - it might not work. Decide
if you're willing to chance that, and if you're willing to lose the money it
costs and the time involved in its application it it doesn't work.
It's interesting to try new [to us] products, but there is always a possibility,
that if used in a manner other than recommended, it may not work or
cause one more problems that will need to be dealt with later. It's the old
'Sometimes you win - Sometimes you lose.'
mezmo
Images: 194
Postby Irving » Thu Mar 21, 2013 7:01 pm
Got a start on my build over the last few days. Here are a few pictures. I wasn't too let down by the harbor freight trailer. I was glad to see that it is all 1/8" steel. We welded a few key spots to be sure it will be very strong. I also sprayed it a dark green.
Irving
Re: New 6 x 10 travel trailer build under way
Postby Irving » Fri Mar 22, 2013 6:46 pm
Irving
Postby Irving » Fri Mar 22, 2013 7:28 pm
Has anyone covered their underbody with canvas and tightbond to protect it from the elements?
Irving
Postby WhitneyK » Fri Mar 22, 2013 11:10 pm
Irving wrote:Image
IRVING!!!!!
I hope that's not your wifes good card table!? :shock: :o :frightened: ;) :lol: :D
Whitney & Tracie
Crothersville, IN
We never really grow up, we only learn how to act in public.
Do not confuse what you hear with what I mean.
My build: http://www.tnttt.com/viewtopic.php?t=41955
160061-------------------------------101114
States we've drug our
li'l camper through. (44 States + Vancouver Island and over 45,000 miles so far)
WhitneyK
Images: 412
Postby KCStudly » Sat Mar 23, 2013 1:52 am
+1.
I hope it doesn't collapse in the dirt due to overloading and crush your foot! :shock:
Please be careful. :worship:
Postby Irving » Sat Mar 23, 2013 9:39 am
Settle down people. Don't worry, I made it past this step alive. I know, I like to live dangerously.
Irving
Postby WhitneyK » Sat Mar 23, 2013 3:46 pm
Irving wrote:I know, I like to live dangerously.
Are you refering to putting that much weight on a card table or when your wife finds out what you DID to the card table? :lol:
Whitney & Tracie
Crothersville, IN
WhitneyK
Images: 412
Postby Irving » Mon Mar 25, 2013 7:14 pm
Canvas covered underbody. Used watered down tightbond 3.
Irving
Postby WhitneyK » Mon Mar 25, 2013 8:17 pm
Thinkin' about a coat or two of paint? :thinking:
Worked for the old airplanes, should work at 70 mph. :thumbsup:
Whitney & Tracie
Crothersville, IN
WhitneyK
Images: 412
