Kamp King last pics, journal is complete.
Re: Kamp King closed in!
Postby doug hodder » Sun Mar 24, 2013 6:49 pm
Thank you all for the positive feedback and compliments! If my projects provide inspiration, that's great and thank you. I really enjoy the building process and trying to come up with something a little different each time. There are so many great trailers full of ideas out there that I doubt I'll ever get to build all the stuff I'd like to. In the mean time...it's one at a time. It is hard to let them go however. Doug
Postby aggie79 » Mon Apr 01, 2013 4:39 pm
Fantastic as usual Doug!
Some time, if you get a chance, could you fill us in a little more about the door frame, please - metal gauge, dimensions, etc.? I recall seeing you made the door and screen door hinge on the Nomad. Are you using this same method?
Thank you for your creativity and time,
Postby doug hodder » Wed Apr 03, 2013 3:37 pm
This door is being built the same way. However, this time...it's got a thicker jamb so that I don't have to relieve the back side of the screen to fit. I'll get some dimensions on it. Doug
Postby Ron Dickey » Wed Apr 03, 2013 8:54 pm
doug hodder wrote:This door is being built the same way. However, this time...it's got a thicker jamb so that I don't have to relieve the back side of the screen to fit. I'll get some dimensions on it. Doug
I am doing the same on my new build too. it will give the hinges a better set and the lock will be even stronger.
Look good doug
What colors are you putting into this one? the front of the Cross bow inside I am thinking of putting in fabric on the wall instead of wood, but with my luck it will have something fly trough it on one of my travelings.
:thumbsup: :applause:
Ron Dickey
173882......173887
Ron Dickey
Images: 787
Postby jeporter25 » Thu Apr 04, 2013 10:21 am
Great build Doug, Your attention to detail and finish quality really set it apart. In a world of Ikea furniture and disposable junk made half way around the world It's good to see that there are still some real craftspeople around. My hat's off to you.
jeporter25
Postby doug hodder » Sun Apr 07, 2013 5:52 pm
For those of you interested in the door frame construction, here's the info. I get 16ga. sheet metal bent into a Z shape, I buy 3 6' pieces. The drop will be used to alter the hinge for the screen. It has a 1" outer flange, 2.25" deep inside, and 1/2" inner lip. How deep you make it depends on just how much door you want to put into it. The latch I'm using takes a minimum of 1.25" thickness, my screen door 3/4", tears wouldn't need to be so thick as the typical latch/ handles can be put into just about any thickness. You have to include thickness of the outer door, screen door, and enough room to squish the bulb weather seal. The Nomad required me to do some routing on the screen door to make it fit, so on this one I went deeper. On a standy, the advantage of the 1/2" inner lip is that it keeps water from rolling in from under the door due to excessive road splash. I just miter the corners and weld it up to fit the opening. Large flange to the outside, small inner flange on the inside, just keep it square.
I then take the outer door and mate it to the inner door. Both doors are made on the table in a jig I make up so they are identical in size. Cut 1 side of the hinge on an odd number of knuckles so that you have 3 flaps that are independent of 1 side of the hinge. I cut up some of the door jamb drop and weld it to the hinge flap so that it captures the screen. To attach the screen, I use some small screws through the door, not just a wood screw to hold it in place.
Once I figured out that my eye glass prescription had changed and the progressive lenses weren't working to weld...I put on the lined bi-focals and my welds came out cleaner. At any rate...I grind them smooth and hit them with a shot of bondo so they really look nice.
Full length hinge:
The outer door will be skinned in aluminum, then centered in the jamb, allowing some space for weatherstripping, then I attach the hinge to the jamb with a series of screws. I only do a couple first to make sure it's going to work before I blow a ton of holes in the jamb. I trim out the door with 1.5" x 1/8" aluminum strap and allow it to overhang the opening with enough overhang to take a small bulb seal for weatherstripping. Once fit up...then mark the jamb for the latch and deadbolt. Once marked, I drill them out and work them with a metal blade in the scroll saw and a file, kind of a pain. No pics...I'm not there yet.
Stuff to watch out for...remember which side is up and inside on the doors. The screen door needs to be built so that when you mate the 2 doors together, that the latch fits completely in the screen door opening with the slider on it. Typically, you will need to relieve some material on the screen vertical to allow for the latch. Also...I've found it's a good idea on a scratch built screen door to beef up the bottom and top of the slider in case you try to shut the outer door when the slider door is shut. I found out the hard way. I use poplar for the screen and outer door construction. It works easily, takes paint/ screws great and is less prone to warping. I tend to make my doors beefy as they get used a lot and I've seen tons of older trailers with "floppy" doors. The same process can be done in aluminum, but I'm not set up to do the aluminum welding anymore. I'd imagine that the same process could be done with any thickness door combination, but this is what I'm doing.
Hope this is what you wanted. Doug
Postby aggie79 » Sun Apr 07, 2013 6:01 pm
Thank you very much Doug. Very nice design and detailed description and pictures. I've placed this in my design file.
Postby doug hodder » Sun Apr 07, 2013 6:03 pm
This weekend, I got the rest of the wiring run, got it all insulated except the very top of the roof, started on putting the sub skin on it, and got the screen and outer door hinged and mated up. I also managed to put a big scratch in a drawer front...rats! Doug
Re: Kamp King door info + update 4/7
Postby Oldragbaggers » Sun Apr 07, 2013 6:51 pm
Wow!! I really love the shape of this trailer. Magnificent job, Doug.
Life is sooooo good.........
Sail...camp....bike...repeat
Becky
Oldragbaggers
Images: 331
Postby Jdw2717 » Sun Apr 07, 2013 8:11 pm
Every time I see this build it makes me want to try and build one that size. Maybe some day, but until then I guess I will just follow and admire yours. Keep the pictures coming.
"Twenty years form now you will be more disappointed by the things that you didn't do than by the ones you did. So throw off the bowlines... Explore. Dream. Discover" Mark Twain
John & Tatanya
Jdw2717
Images: 34
Postby S. Heisley » Sun Apr 07, 2013 8:43 pm
I think that this is going to be the best trailer that Doug has built to date!
(I noticed that you also made a step for in front of the door....Nice looking.) :thumbsup:
Postby doug hodder » Sun Apr 07, 2013 8:58 pm
Thanks Sharon, I don't think of it as being the best, it's just different...The step is just for the shop and while building. I got tired of making the step up, especially when carrying stuff so that I wouldn't bang a wall. I have an actual bolt on retractable step that slides under the body. However, since it was bent and I had to do a bunch of work on it, if it doesn't work out...I'll "doll" up this step and use it till I get a replacement. Doug
Postby doug hodder » Sat Apr 20, 2013 10:36 pm
I got a fair amount of work done today. Striped and installed the overhead doors, made all the 12V electrical connections at the fuse box and tidied up the wiring, installed the backsplash, did the final attachment of the counter tops, made the final connections on the plumbing, stained and sprayed the screen door and did some preliminary fit up on the doors. I also got the name badging/logo cut in vinyl so it's ready to install once I get the paint on it.
It's all skinned with the luan, with the exception of the roof and that won't happen till I lower the trailer, there is no room to do that work as it sits. I'm not going to do that until I get the aluminum skin on the sides and the front and get it painted, ( 3 colors on the sides). That way I won't have to deal with any "blow back" on the spraying since it's going to be so low on the ground once I lower it. I'll shoot the roof material first then install it once the trailer is lowered. I kinda changed my plan of attack on using some of the original aluminum siding in an attempt to shorten the build time. Besides, the panels weren't going to be tall enough for what I wanted. I probably won't get the aluminum for the siding till after the Dam. I decided I needed a break since I haven't taken off a weekend since November...so I'm going camping!!!
This last week, I also managed to get all the curtain panels made, themed fabric with a black flange and a gray top for the rod. Doug
Re: Kamp King update 4/20
Postby KCStudly » Sat Apr 20, 2013 10:45 pm
The theme works throughout. Very nice quality, it can not be said enough. We first time builders are living in the shadows of true masters. :applause:
Postby nevadatear » Sun Apr 21, 2013 10:33 am
Wow de wow wow! :thumbsup:
nevadatear
Images: 171
