halfdome, Danny wrote:As mentoned before, butyl tape will work.
I've used it in certain areas.
I use OSI QUAD available at Home Depot.
It sticks to aluminum very well.Danny
aggie79 wrote:halfdome, Danny wrote:As mentoned before, butyl tape will work.
+1 on the OSI Quad. I also used 3M 4200 but you have to order online unless you happen to be near a marine supply store.
markhusbands wrote:So I have never used butyl tape...any tips on applying it? Is it as easy as rolling it out and pulling off the backing? And how much space does it take up under the trim?
TPMcGinty wrote:markhusbands wrote:So I have never used butyl tape...any tips on applying it? Is it as easy as rolling it out and pulling off the backing? And how much space does it take up under the trim?
It comes in various widths. It is real easy to apply. All I did was take off the backing as I applied it to my windows and vent fan. Then I just screwed down the windows and fan and it sealed just fine. After that I pressed down the butyl tape that oozed out of under the window frame to make it look nice and professional.
