Best way to seal windows/roof vents/door casings
Postby Irving » Thu Apr 04, 2013 10:59 pm
What is a good way to seal these things? Some type of tape? Any specific brand? Caulking?
Irving
Re: Best way to seal windows/roof vents/door casings
Postby TPMcGinty » Fri Apr 05, 2013 6:39 am
I used butyl tape the when I refinished my tear.
Tim
TPMcGinty
Images: 146
Postby halfdome, Danny » Fri Apr 05, 2013 7:28 am
As mentoned before, butyl tape will work.
I've used it in certain areas.
I use OSI QUAD available at Home Depot.
It sticks to aluminum very well.
:D Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby Oldragbaggers » Fri Apr 05, 2013 7:58 am
I am using butyl tape also, and putting 3M 5200 sealant into my screw holes.
Life is sooooo good.........
Sail...camp....bike...repeat
Becky
Oldragbaggers
Images: 331
Postby aggie79 » Fri Apr 05, 2013 2:35 pm
halfdome, Danny wrote:As mentoned before, butyl tape will work.
:D Danny
+1 on the OSI Quad. I also used 3M 4200 but you have to order online unless you happen to be near a marine supply store.
Postby halfdome, Danny » Fri Apr 05, 2013 3:22 pm
:D Danny
Just bought a tube of OSI Quad today @ $5.98 a tube + tax :BE .
They sure beat you up on the price of petroleum based products lately.
:D Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby Irving » Tue Apr 09, 2013 9:32 am
I see OSI Quad as a caulking when I look it up. Does it also come as a tape? If you use the caulking form, do you simply run a thick bead around all edges of the window before screwing down?
Irving
fixing a hole in the roof
Postby Irmo Atomics » Wed Apr 10, 2013 4:54 am
I got a little carried away with the rivets, but make sure you mask off the area that you don't want to get any caulk on.
Bob
Irmo Atomics
Images: 64
Postby prohandyman » Wed Apr 10, 2013 6:06 am
Pro Flex RV sealant, remains flexible, $10 a tube online. Used by most manufacturers.
Dan
prohandyman
Images: 785
Postby markhusbands » Wed Apr 10, 2013 6:59 am
So I have never used butyl tape...any tips on applying it? Is it as easy as rolling it out and pulling off the backing? And how much space does it take up under the trim?
133923
markhusbands
Images: 58
Postby TPMcGinty » Wed Apr 10, 2013 9:43 am
markhusbands wrote:So I have never used butyl tape...any tips on applying it? Is it as easy as rolling it out and pulling off the backing? And how much space does it take up under the trim?
It comes in various widths. It is real easy to apply. All I did was take off the backing as I applied it to my windows and vent fan. Then I just screwed down the windows and fan and it sealed just fine. After that I pressed down the butyl tape that oozed out of under the window frame to make it look nice and professional.
Tim
TPMcGinty
Images: 146
Postby Irving » Wed Apr 10, 2013 2:57 pm
Did you use only the tape? Or did you also use caulking on the screws and screw holes?
Irving
