FoamStream...
Re: FoamStream...
Postby atahoekid » Thu Jun 06, 2013 12:37 pm
Looks real good... I think we've all miscalculated. So much for the superior parochial school education I got, I apparently can't do basic math. :oops: :shock: I was an inch off when I rebuilt the rear doors of Road Foamie. I couldn't use spray foam to fix the mistake but I should have used it to shut my pie hole during my obscenity laced tirade :x :x :o Can't wait to see the next step. Nose or rear door?
Mel
atahoekid
Images: 158
Re: FoamStream...
Postby GPW » Thu Jun 06, 2013 12:42 pm
Thanks Guys , just fighting the everyday rain and the horseflies (little buggers :x worst season ever...) hopefully today I can get the other top panel glued up and start the keystone ... I did make a quick run to the Grocery for food and more cans of Great Stuff ... :D
Not to worry , my math is dead awful ... as one can readily see... :roll: ... :lol: :lol: :lol:
Re: FoamStream...
Postby GPW » Thu Jun 06, 2013 1:40 pm
Got the last piece glued up , measured the keystone ... 8.25” bottom , 9.75” top X 10’long ... an angle cut ... grrrr!!! I’ll just set up two boards staggered and cut it with the hot wire bow ... most accurate way I can think of .... at the moment ... :thinking:
Ps. if i’m boring everybody with these pictures , please let me know ..
Re: FoamStream...
Postby aggie79 » Thu Jun 06, 2013 1:45 pm
Looks fantastic GPW! Keep the progress and pictures coming.
Re: FoamStream...
Postby GPW » Thu Jun 06, 2013 1:50 pm
OK, Thanks !!! :pictures:
Re: FoamStream...
Postby atahoekid » Thu Jun 06, 2013 2:03 pm
GPW wrote:Got the last piece glued up , measured the keystone ... 8.25” bottom , 9.75” top X 10’long ... an angle cut ... grrrr!!! I’ll just set up two boards staggered and cut it with the hot wire bow ... most accurate way I can think of .... at the moment.
Will the keystone cut produce a flat top that will mess up the otherwise perfect curve? Maybe just one more small kerf cut section?????
Mel
atahoekid
Images: 158
Re: FoamStream...
Postby GPW » Thu Jun 06, 2013 2:15 pm
Yes, Schmaybe a kerf or two , but the keystone will be 4.5” thick , so I can round out the excess nicely ... just more sanding .... going to be a lot of that :o ... Stupid me , I should have done this when it was Cool weather ... :duh:
Re: FoamStream...
Postby Wobbly Wheels » Thu Jun 06, 2013 2:29 pm
Just a thought, but what about cutting the keystone to the narrowest width and back filling the long triangular gaps with canned foam ?
Since you've got the ladder out anyway... :D
Wobbly Wheels
Re: FoamStream...
Postby GPW » Thu Jun 06, 2013 4:10 pm
W2, that’s entirely possible ... :thinking: I’ll try this way first and if it doesn’t fit , we’ll just spray foam it in ... 8) :lol: :lol: :lol:
Re: FoamStream...
Postby GPW » Thu Jun 06, 2013 5:25 pm
Raining again , so I threw the tarp over it ... again .. getting good at that now ... much practice ... :roll:
So , inside the Studio , I laid out the Keystone ... allowing for the extra inch of thickness for “rounding" ... Too tired after the Heat and swatting flies all day ... grrr! Will hot wire the keystone out tomorrow ... once I’m better rested and have an attitude adjustment ... :beer:
Re: FoamStream...
Postby mezmo » Fri Jun 07, 2013 1:30 am
Oh Yes - the pics are Necessary !
[We all enjoy seeing your progress.]
mezmo
Images: 194
Re: FoamStream...
Postby kudzu » Fri Jun 07, 2013 6:35 am
Love pics. Keep those coming. It's great to see this really taking shape.
kudzu
Images: 16
Re: FoamStream...
Postby Ned B » Fri Jun 07, 2013 8:36 am
GPW, Looking Great! Where are you with the nose pieces, did your CNC guy cut out the arches for you yet?
Ned B
Re: FoamStream...
Postby GPW » Fri Jun 07, 2013 8:37 am
OK, I got the first angle cut on the Keystone by using boards as templates ... Had to measure carefully the edges of the boards where the wire would ride on would line up with the intended cut ... :thinking: Came out OK, a little sanding will true things up quickly ... here’s the pics , on to the second cut now ...
Ned , not yet as I know ... been sorta’ “lost in time” building this ... dawn to dusk ...
Re: FoamStream...
Postby GPW » Fri Jun 07, 2013 10:00 am
Here’s the keystone ... a little sanding (outside) and we’ll check the fit .... if it’s too Large , we’ll sand more .... if it’s too small :oops: (that Math thing) , there’s spray foam ... :D
Minutes later ...
And it Fits !!! :o ... :dancing :woohoo: Buttered up the sides with T2, slid it in and clamped it with a 10’ board... There is a bit that sticks up ... plenty for trimming and rounding .. 8)
