GPW wrote:George , what were they thinking ? .... mounted high on the wall, raising the center of gravity , and over a window where it can leak down and rot the window opening and surrounding wall ...a Very expensive fix at an RV dealers... I really wonder sometimes about RV designers...
Bogo wrote:You may wish to make the bottom of the AC hole sloped a bit to the outside so rain water drains out, rather than puddles. Also look at what the AC unit expects for mounting.
GPW wrote:Bogo, the drain angle will be adjusted by the spacer I put on the floor , got that sorted. Thanks !!!![]()
