The Big Pink, Foamie !
Re: the big Pink ... con't
Postby tac422 » Thu Jul 11, 2013 9:28 am
KC,
I used round toothpicks to hold the trim in place, which worked well. But the glue kept running to the bottom and dripping off.
Sanding the plastic is a good idea, and would certainly help, but I've good about 90 ft of trim to do, and the gripper works well.
tac ( who finally figured out how to have an Avatar !)
tac422
Re: big Pink ... con't
Postby atahoekid » Thu Jul 11, 2013 3:28 pm
Hey tac, have you thought about using Great Stuff as an adhesive? The stuff seems to stick to everything and you need to knock it down when using it, but if you can control the foaming and swelling, it might work. Not too hard to sand either if it gets outta control and you can't get it knocked down before it dries. Just a thought...
Mel
atahoekid
Images: 158
Postby eaglesdare » Thu Jul 11, 2013 4:40 pm
Forgive me for having CRS (can't remember sh* umm stuff), but what site did we meet at?
I am so happy that you got Mike's foamie! What a great start you have there. Looking forward to watching you finish it. :wine:
Louella
May the foam be with you.
eaglesdare
Re: The big Pink
Postby kudzu » Thu Jul 11, 2013 8:40 pm
tac422 wrote: Here's a close up of the Gripper.
109429
I like the look of that drywall edging. I think it could be useful in a number of areas. (And cover up a multitude of sins I'm likely to commit. :lol: )
kudzu
Images: 16
Postby tac422 » Tue Jul 16, 2013 7:45 am
I installed some of the rounded corner yesterday.
The lower curve is as tight as it will go. I should probably have trimmed several tabs just a tiny bit as they overlapped slightly, but by the time i saw that everything was covered in gripper and pinned in place.
I plan on using corner molding on every exposed corner. You can't see in the picture , but I put corners on the inside of the bottom as well.
These overlapped the outside corners, but seemed to get good adhesion. This should protect the bottom pretty good.
109916
closeup of rounded corner
109917
tac422
Postby GPW » Tue Jul 16, 2013 9:54 am
That looks Very Nice !!! :thumbsup: 8)
Postby mikeschn » Thu Jul 18, 2013 6:23 pm
Hey TAC, you're off to a good start. Glad to see that.
Over here I've gotten spread too thin with trying to figure out the new Winter Warrior with fiberglass etc. I didn't have the time, energy or resources to figure out the foamie too. I'm glad you have the time, energy and resources to figure out the foamie. We'll be watching with great interest.
Postby CampsALot » Thu Jul 18, 2013 6:29 pm
That's a cool idea.
Looks great !!
Hmmm... :thinking:
Warren
Foam Away From Home
106754106755
Start of Build Thread viewtopic.php?f=50&t=55752
New Build Thread viewtopic.php?f=55&t=56489
CampsALot
Images: 74
Postby tac422 » Fri Jul 19, 2013 3:17 pm
Mike,
THANK YOU again. I'm taking my time, and trying to do a good job ... :D
I'm still figuring it out as I go along !
So, I'm still doing trim ... I have a lot to do. Today I worked on the door...
Original hole
110035
So I played around with the drywall molding. I cut every other hole, and it nicely bent into this.
110034
This is before the gripper with 2 pieces (inner and outer) in place.
110036
After the gripper
110037
Closeup after.
110038
tac422
Postby atahoekid » Fri Jul 19, 2013 11:52 pm
So TAC, Are you adhering the moulding with just Gripper. If so, I am amazed at the adhesion you're getting and I used Gripper. Wow!!! BTW, I so wish I had thought of that before I did my build
Mel
atahoekid
Images: 158
Postby tac422 » Sat Jul 20, 2013 6:25 am
Mel,
I'm just using Gripper, I tried TB2 and it didn't work at all for me...
But I was using it upside down on smooth plastic.
The Gripper is doing great, plus everything will be covered in canvas.
tac422
Postby GPW » Sat Jul 20, 2013 7:41 am
Super idea Tac!!! :thumbsup: 8)
Postby tac422 » Thu Jul 25, 2013 6:22 pm
I covered the door in canvas using TB2. I was going to use Gripper, but GPW's results showed that TB2 was better... Thanks GPW !
I still like Gripper for the molding.
110236
door window finished
110237
tac422
Postby GPW » Fri Jul 26, 2013 5:41 am
Looks Great Tac!!! It’s all about finding the right glue for the right job !!! That’s gonna’ be one NICE Foamie !!! :thumbsup:
Postby tac422 » Fri Jul 26, 2013 4:46 pm
I got some more molding on today, the right side is almost done. I still have to do the front inside bottom.
110274
tac422
