#1
Re: #1
Postby GPW » Sun Jul 07, 2013 6:26 am
Living hinge... :thinking: How about taking two pieces of heavy canvas, sew them together across the middle with something strong like kevlar thread , then “rubberize “ that section ... install it as a hinge .. ? We’ve been using hinges like this on foam planes for years ... they never fail, and they don’t leak ... ... :thumbsup:
canvas hinge.jpg (61.46 KiB) Viewed 1601 times
Re: #1
Postby ghcoe » Sun Jul 07, 2013 2:01 pm
Good ideas. :thumbsup:
George.
ghcoe
Re: #1
Postby ghcoe » Sun Jul 07, 2013 2:12 pm
Working on the hatch some this morning.
Getting it straight
DSCF2129 small.jpg (135.4 KiB) Viewed 1586 times
New roof piece is installed.
Roof piece on
DSCF2130 small.jpg (132.48 KiB) Viewed 1586 times
Next to bolt the frame rails back in. They came off to be stained and varnished. Now I need them back in to align the body to the floor.
Frame rails
DSCF2014 small.jpg (96.47 KiB) Viewed 1586 times
George.
ghcoe
Re: #1
Postby GPW » Sun Jul 07, 2013 2:47 pm
Really coming along Nicely George !!! :thumbsup: 8) :D
Re: #1
Postby ghcoe » Sun Jul 07, 2013 3:29 pm
Thanks! It would come along a lot faster if I did not have to sit and think about how to do things, but then it probably would not be so much fun. Already building a bigger unit in my head. This trailer has really got the wheels turning now..... :thinking:
George.
ghcoe
Re: #1
Postby GPW » Sun Jul 07, 2013 4:44 pm
Foamies are just like Potato chips (crisps) , You can’t have just One ... :lol:
Re: #1
Postby kudzu » Sun Jul 07, 2013 5:21 pm
GPW wrote:Living hinge... :thinking: How about taking two pieces of heavy canvas, sew them together across the middle with something strong like kevlar thread , then “rubberize “ that section ... install it as a hinge .. ? We’ve been using hinges like this on foam planes for years ... they never fail, and they don’t leak ... ... :thumbsup:
LIKE! :thumbsup: Thanks GPW!
kudzu
Images: 16
Re: #1
Postby Fyddler » Sun Jul 07, 2013 7:15 pm
For my galley hinge I used a piece of old fire hose. It is made from rubber and nylon. This was from 5" hose, so it's real thick, probably to thick for a door but same idea.
To err is human, to really foul up requires a computer
Build Log: http://www.tnttt.com/viewtopic.php?f=50&t=55017
Fyddler
Re: #1
Postby ghcoe » Sun Jul 07, 2013 8:39 pm
Got too hot here to work on the foamie much. I did manage to get a couple frame rails installed and made my front wall extension.
front wall extender
DSCF2131 small.jpg (125.65 KiB) Viewed 1553 times
I used 2"x3" flashing to go under the floor and attach with the bolts that hold the forward inner frame rail in place. This will give a nice hard edge along the bottom of the front wall and will help hold the wall in place better than just gluing the wall to the OSB edge.
Side view
DSCF2132 small.jpg (119.84 KiB) Viewed 1553 times
With foam
DSCF2134 small.jpg (142.4 KiB) Viewed 1553 times
George.
ghcoe
Re: #1
Postby atahoekid » Sun Jul 07, 2013 11:15 pm
ghcoe wrote:Thanks! It would come along a lot faster if I did not have to sit and think about how to do things, but then it probably would not be so much fun. Already building a bigger unit in my head. This trailer has really got the wheels turning now..... :thinking:
Although I thought I had planned a lot of the build, there were lots of time, I found myself staring at the build thinking... 10 - 15 minutes at a time. Maybe it was day dreaming but I did find myself sketching a lot after those episodes of contemplation. Part of the fun. Exercising the ol' noodle :thinking: :thinking: :thumbsup: :thumbsup: If I had a job that required such imagination, I might not have built the Road Foamie, so in the long run, I guess I should be grateful for a boring job.... :lol: :shock: :o
Mel
atahoekid
Images: 158
Re: #1
Postby GPW » Mon Jul 08, 2013 7:30 am
Foamies ... The “thinking man’s trailer “ ... ladies too ... :thinking: ... Thinking is Good !!! :thumbsup: Just beware of Imagination ... that can go both ways and be either very creative or quite a distraction from purpose ... :roll:
Re: #1
Postby ghcoe » Sat Jul 20, 2013 3:47 pm
Did a bit of work today. Got the last piece on the front.
Front
DSCF2140 small.jpg (70.73 KiB) Viewed 1472 times
Inside front
DSCF2141 small.jpg (98.01 KiB) Viewed 1472 times
One thing I notice while working today is that the foam on the front is turning color. Looking closer at it I realized that it was deteriorating from sun exposure. So keep your foamies out of the sun until you get them covered.
George.
ghcoe
Re: #1
Postby GPW » Sun Jul 21, 2013 5:42 am
George , we found that on extruded foam , intense photon bombardment causes the surface color to fade , but the underlying area is unaffected ... on bead board the process is much accelerated , weakening the bond between the beads on the surface , but un-affecting their composition ... but all that takes a long time to happen ... No worries unless you build Really SLOW ..... like me ... :lol:
Re: #1
Postby eaglesdare » Sun Jul 21, 2013 7:17 am
Just caught up on this one. Wow, what a wonderful job you are doing. You will be out and about enjoying your foamie soon. :applause:
Louella
May the foam be with you.
eaglesdare
Re: #1
Postby Bogo » Sun Jul 21, 2013 7:53 am
I have some unprotected pink foundation foam that has eroded around a half inch in a decade. It's fully exposed to the weather, including getting full sun for the morning.
Bogo
Images: 39
