Re: Thrifty Alternatives ... Building Foam TDs
Postby Jack B. » Thu Sep 12, 2013 8:00 pm
How did I not know about all this progress? I was laboring under the belief that it was still mostly concept. What other magnum opus am I missing out on? And to top it all off I've got another 123 pages to read.
Jack
Jack B.
Postby GPW » Thu Sep 12, 2013 8:32 pm
Well, it all happened overnight, sorta’ ... in the last four months ... :o But not to worry ! Since I have a whole sheet of Blu foam left over , I take that as a sign to build another ... :roll: FoamStream V.3 :frightened: Gotta’ be Thrifty !!! ;)
Postby atahoekid » Thu Sep 12, 2013 10:27 pm
That's the one I wanted to see built!!! I think it is a very cool design... Do you have the frame? I know you were collecting them at one point, do you still have them?
Mel
atahoekid
Images: 158
Postby GPW » Fri Sep 13, 2013 5:22 am
Still have that other trailer waiting ... :thinking: Might be Nice to build during the cooler weather ... :D
Postby luneywan » Fri Sep 13, 2013 4:37 pm
Finished at last. :D
I knew it was going to be tough when I was about a third of the way through and people were already talking about how long it took them to read the thread. :frightened:
Took me five (5) weeks, and I was on vacation for two of them. :lol:
Now all I need is for my wife to agree on a foamy.... :noyes: :worship: :lol: :lol: :lol:
Luneywan
luneywan
Postby GPW » Fri Sep 13, 2013 4:47 pm
Lune' ... Now you know as much as we do !!! :thumbsup: 8) Congratulations !!! :applause: Now it’s all ‘salesmanship” ... :lol:
Thinking about #3 ... it seemed a bit long eh ? ... around 18’ ... :o so here’s a shorter more manageable size ... still @ 15’ it’s no small trailer ... :thinking:
Next step is to completely re-design it to fit a 4’X8’ sheets of foam ... Thrifty !!! :thinking: ... and we don’t want any leftovers , because then we’d have to build another one , and we’d be out of out of trailers ... :frightened:
Foamie #3.png (191.58 KiB) Viewed 650 times
Postby GPW » Sat Sep 14, 2013 8:15 am
Here’s a basic layout drawing using 4’X8’ foam sheets .. Just seeing what will fit within those restrictions ... :thinking: Really like the way the top goes toward the nose and flares out wider ... That should look Cool !!! 8)
Postby Mary C » Sat Sep 14, 2013 8:58 am
Congratulations!!!you did it!! :thumbsup: Now is the time to digest what you read and to plain your build but I warn you this is habit forming! Good luck!
Mary C. :)
Mary C
Images: 473
Postby GPW » Sun Sep 15, 2013 8:06 am
A thought about trailer floors:
So far we've used plywood and OSB for trailer floors , both having their pros and cons. But common to both has been a sharp edge on the bottom where it contacts the canvas . It’s such a small thing to consider , but wouldn’t it be “better” to round off this bottom edge to a radius , which would lessen the stress on the skin at this point as it wraps under the floor ... Plywood is not so bad to do this with a router and round over bit , But OSB is pretty TOUGH... and doesn’t work so easily .. dulls a router bit quickly , and just laughs at my belt sander with the coarsest grit I can find ... Now thinking I should cut my OSB floor panels on a slight angle to at least pre- remove a good bit of what would be rounded ... :thinking:
Any other thoughts on this ... ?
floor edge.jpg (76.82 KiB) Viewed 579 times
Postby Ned B » Sun Sep 15, 2013 8:14 am
GPW wrote:A thought about trailer floors:
GPW, I'd bet that a 45°Bevel would be more than sufficient to ease the sharp corner off for the grade of canvas we're using. If the 45° doesn't ease it enough it Certainly is a better starting point than a 90° cut.
Ned B
Postby GPW » Sun Sep 15, 2013 10:18 am
Yeah Ned , I was thinking any sharp edge, meeting canvas, if it rubbed on something (who knows? ) would slice the canvas at that point , and there goes the “sock” :o Some simple rounding of any kind would lessen the stress to a large degree. Easy enough to do before the floor is mounted to the trailer . We Do want these Foamies to last “forever” eh ? ... ;)
Postby luneywan » Sun Sep 15, 2013 4:15 pm
Mary C wrote:Congratulations!!!you did it!! :thumbsup: Now is the time to digest what you read and to plain your build but I warn you this is habit foaming! Good luck!
Mary C. :)
Corrected you spelling. :lol:
luneywan
Postby luneywan » Sun Sep 15, 2013 4:19 pm
Or we could add a rounded lip/ Maybe corner moulding. It's cheap and easy to work.
Just thinking, it would be good to round inner and outer edges. Spread the stress out to a greater area.
Just my 2 copper pieces.
luneywan
Postby GPW » Sun Sep 15, 2013 4:39 pm
Lune’ , quarter round moulding would work too ... Good idea !!! :thumbsup: Less mess !!! 8)
See, Luneywan is already thinking like the rest of us ... :D
Postby wagondude » Sun Sep 15, 2013 5:32 pm
Or rabit the edge of the foam to leave 1/2" of overhang past the edge of the floor and just round the foam. But beveling the floor edge and then covering with the radiused drywall corner bead would probably be easiest. And we have seen how well that drywall edge works on a couple of trailers now.
BTW: three more pages till we break 400.
Bill
101137
wagondude
Images: 35
