How did I not know about all this progress? I was laboring under the belief that it was still mostly concept. What other magnum opus am I missing out on? And to top it all off I've got another 123 pages to read.
Jack
GPW wrote:A thought about trailer floors:
So far we've used plywood and OSB for trailer floors , both having their pros and cons. But common to both has been a sharp edge on the bottom where it contacts the canvas . It’s such a small thing to consider , but wouldn’t it be “better” to round off this bottom edge to a radius , which would lessen the stress on the skin at this point as it wraps under the floor ... Plywood is not so bad to do this with a router and round over bit , But OSB is pretty TOUGH... and doesn’t work so easily .. dulls a router bit quickly , and just laughs at my belt sander with the coarsest grit I can find ... Now thinking I should cut my OSB floor panels on a slight angle to at least pre- remove a good bit of what would be rounded ...![]()
Any other thoughts on this ... ?
Mary C wrote:Congratulations!!!you did it!!Now is the time to digest what you read and to plain your build but I warn you this is habit foaming! Good luck!
Mary C.
Users browsing this forum: Google [Bot] and 8 guests
