Gage wrote:A little common sense would have prevented that. Something a lot of first time builders don’t seem to have or even know what it is.
You're so wise! Not, very diplomatic though. I knew moving it would be difficult, but I accept all challenges. Common sense doesn't figure in to the equation...assuming infallibility overrules it. As you probably know.Gage wrote:A little common sense would have prevented that. Something a lot of first time builders don’t seem to have or even know what it is.
halfdome, Danny wrote:When I've pulled a teardrop, I've been building, out of my shop & into my downhill slanted driveway, I place 2 x 4's in various spots to catch the wheels, this prevents a runaway.
When I push it back into the shop, I level it out with the tongue wheel and then go a bit more so I'm not pushing all the weight, uphill, by myself.
You've got to take care of yourself as no one else will.Danny
working on it wrote:Same problem here. There was no problem to manhandle the trailer when it was just shell. But now, much different. My trailer weighs in at 1280lbs without consumables packed, 1438lbs with. My driveway slopes up from the trailer's garage bay at about 8-10 degrees. No problem pulling it out with the truck, but to turn it around and back it in, that's another story. The driveway layout makes me drive it in forward about 110 feet, take a 90 degree turn , then drive forward and turn right about 45 degrees another 30 feet on. From there, I unhook the trailer, use the foot pad on the jack to dig into the sand, and swing it around by hand another 90 degrees, back the truck out to the street, turn it around, then back it all the way in, and re-hook the trailer. Then the truck is used to maneuver it into the garage (another 20 feet at a 45 degree angle). I tried it once, all the way by hand...fortunately I was able to stop the runaway trailer by forcing the jack pad to dig in about 8" into the sandy drive. I've got to come up with a better method; either way I've tried, the trailer calls all the shots, and is a backbreaker to turn on the sand.
halfdome, Danny wrote:When I've pulled a teardrop, I've been building, out of my shop & into my downhill slanted driveway, I place 2 x 4's in various spots to catch the wheels, this prevents a runaway.Danny
Gage wrote:halfdome, Danny wrote:[color=#4000FF]And for you two that got upset with my posting, look at it this way, I could have said ‘That was Stupid’, but I didn’t.
Gage wrote:I do the same but use wheel chocks instead of 2x4’s and then use a come-along to get it back in the garage
Gage wrote:I could have said ‘That was Stupid’, but I didn’t.[/i][/b]
