Trailer for Lost Hikers
Postby hiker » Mon Nov 11, 2013 8:33 pm
Currently we have assembled a Harbor Freight 1720 Lb. Capacity Super Duty Utility Trailer, 48" x 96" Haul-Master - item#94564.
No frame modifications, yet.
114233
Currently thinking boxy style stretched from 4x8 to 60-66" length of 8-9', overall height of 6feet, no change in wheel track.
Somewhat like the larger trailers from http://uev.com.au
Specifically this model, but smaller.
Build Journal: Expedition Trailer Mk I http://www.tnttt.com/viewtopic.php?f=50&t=57985
hiker
Images: 41
Re: Trailer for Lost Hikers
Postby Ron Dickey » Mon Nov 11, 2013 10:50 pm
Thought I had seen that design some where! Should be fun to see what you do to improve on what they did and make it your own. I was fond of the TVan also from there. But I am not a 4x4er at least not now. My cousin is the 4x4er in the family and a desert rat too.
Good luck on your build.
Ron
173882......173887
Ron Dickey
Images: 787
Postby hiker » Tue Nov 12, 2013 6:05 am
We usually drive on some kind of road. Not the hardcore off roader by any means. but have been known to ford small (no snorkel) creeks.
hiker
Images: 41
Postby hiker » Sun Nov 17, 2013 5:37 pm
A little better image of what I am aiming for.
I found this drawing on Google Sketchup
114370
72" high, 64"wide, 9' long.
114371
rear view.
Still measuring my camping gear for compartment sizes.
hiker
Images: 41
Postby 91kuhndog » Sun Nov 17, 2013 9:05 pm
great concept to build... just be carefull building a straightback camper like that. Mine is a straightback and the door height would be a factor if I was over 6' tall. At 5'10", I have about 3" clearance. It stinks to build something only to figure out near then end it doesnt work (as you originally planned). Good luck on the build.
Our only limitations in life are purely self-induced!
My build; viewtopic.php?f=50&t=54749
91kuhndog
Images: 91
Postby hiker » Mon Nov 18, 2013 8:35 am
Thank you, I had not thought about the open height. I was trying to make the height to go under a carport. However that plan is falling by the wayside. I just did dry fit with actual material, found an issue with clearance on the sides. More measuring and possible change of materials.
hiker
Images: 41
Postby hiker » Mon Apr 21, 2014 7:25 pm
119326
Watching glue dry, and the trailer grows to 64" x 96".
hiker
Images: 41
Postby hiker » Sat May 03, 2014 8:17 pm
119703
Floor joists are glued (Loctite PL Premium Polyurethane Construction Adhesive) and screwed.
hiker
Images: 41
Postby hiker » Sat May 03, 2014 8:19 pm
119704
First piece of insulation (Owens Corning FOAMULAR 250 3/4 in. x 2 ft. x 8 ft. R-4 Squared Edge Insulation Board) is glued down.
hiker
Images: 41
Postby hiker » Sun May 04, 2014 8:48 pm
119835
Put the fender bolts on head down. This may prevent tire punctures from the end of the bolt.
hiker
Images: 41
Postby hiker » Sun May 04, 2014 8:49 pm
119836
Wheel well is covered, allowing a flat floor of 64"x 108"
hiker
Images: 41
Postby hiker » Sun May 04, 2014 8:50 pm
119839
Supports for rear overhang.
hiker
Images: 41
Postby hiker » Sun May 04, 2014 8:51 pm
119840
Five (5) rear overhang supports in place.
hiker
Images: 41
Postby hiker » Sun May 04, 2014 8:52 pm
119841
Right rear overhang support, closeup.
hiker
Images: 41
Postby LessisMore » Sun May 04, 2014 11:14 pm
hiker wrote:A little better image of what I am aiming for.
114370
114371
rear view.
I like the YouTube videos of this style, I will be keeping an eye on this build! Best of luck
LessisMore
Users browsing this forum: coal_burner and 8 guests
