swamp cooler
Re: swamp cooler
Postby S. Heisley » Fri Feb 28, 2014 5:23 pm
Forest,
I think you have low humidity in your area, in Utah; so, I think you should be okay with it. I doubt that there would be enough build-up of humidity from the swamp cooler to cause a wood-swelling problem, unless the cooler was blowing directly on the wood...or your tools...could cause tools to rust if it blows directly on them for an extended period. I say go for it.
Re: swamp cooler
Postby bdosborn » Fri Feb 28, 2014 6:54 pm
Oh I fixed the swamp cooler problem, this thingy I bought works great:
Images: 806
Re: swamp cooler
Postby S. Heisley » Fri Feb 28, 2014 9:16 pm
Forest, I think some posts may have caused this thread to drift.
You are talking about putting a swamp cooler in your garage, not your in trailer, correct?
Re: swamp cooler
Postby Forrest747 » Thu Apr 03, 2014 9:34 am
in the garage but trailer works as well.
Forrest747
Cowbell Donating Member
Images: 447
Re: swamp cooler
Postby KennethW » Fri Jul 04, 2014 5:25 pm
I found this on builditsolar.com
http://www.builditsolar.com/Projects/Co ... Cooler.htm
My thought is used with a fantastic fan roof vent you wouldn't need the fans. Just a small water pump in the box hooked on a window. Very light, very low cost , easy to build and good for boon-docking. :NC Bad part is it does not work very good with higher humidity. For the cost it might be worth a try.
Off the subject I have a post on builditsolar that cut my heat bill in half.Really :D
http://www.builditsolar.com/Projects/Sp ... olShed.htm
KennethW
Images: 82
Re: swamp cooler
Postby sagebrush » Sat Jul 05, 2014 7:27 pm
Where I work we took a couple of smaller swamp coolers (About 30" sides) and mounted them on rolling tables about 30" high. Add a long water hose (1/4" plastic airline) and extension cord ,they roll around to where we are working. FEEL GREAT! :thumbsup: :thumbsup: 50' x 100' shop with four 12' x 16' overhead doors so we have plenty of fresh, dry air to cool
We ain't skeer'd of the dark!
Living large in a small way!
sagebrush
Images: 161
Re: swamp cooler
Postby KennethW » Thu Jul 10, 2014 8:55 pm
I am building a evaporator cooler for my teardrop. It will be a evaporator pad in a box over a window using the roof vent to draw air thru the pad box. The water pump will be in a bucket on the ground with the return water running from the pad box down in to the bucket.
The pad box will fit in to the screen slot
122223
The pad box glued to coroplast will replaced screen and will be painted to for UV protection.
122221
Pad box in window
122247
KennethW
Images: 82
Re: swamp cooler
Postby MtnDon » Fri Jul 11, 2014 2:52 pm
This chart may be useful for estimating cooling performance with varying outdoor temperature and humidity
MtnDon
Images: 24
Re: swamp cooler
Postby KennethW » Fri Jul 11, 2014 5:12 pm
A evaporator cooler is a compromise. But if you are boondocking without a generator. It is one of the few options. Sometimes 10 degree is all that is needed to make it semi comfortable. Thanks for the chart.
KennethW
Images: 82
Re: swamp cooler
Postby citylights » Fri Jul 11, 2014 5:46 pm
Anyone that works in their garage in Las Vegas on a regular basis has a swamp cooler attached. I have been thinking about installing one myself. Our humidity hovers 3-8% most of the year. In monsoon season for about 2 months we hover at 30-40%. So for most of the year, they are very efficient cooling.
In my teardrop, I have a 4000 btu air conditioner.
citylights
Users browsing this forum: Bing [Bot] and 6 guests
