ryuandwings wrote:If I may, I would like to chime in with my suggestions.
ryuandwings wrote:1. Would it be possible to extend the hatch over the gutter and possibly add another seal on top side of the gutter to stop unnecessary water from going into gutter? I would hate to see water inside of hatch even though you have the seal. Once the water gets into gutter, only way out is into your galley if something goes wrong.
ryuandwings wrote:2. You may want to look into something like "F" shaped channel instead of making gutter from 2 angles. I still don't know how to turn the corner, but F shaped trim should give you a channel for water with a flange for mount.
ryuandwings wrote:I enjoy your progress very much and keep up the good work.
KCStudly wrote:Each step is a refinement. This latest version looks pretty good.
KCStudly wrote:Is the plan to leave the gutters exposed even when the hatch is closed, or will they be partially/mostly covered?
KCStudly wrote: I appreciate your soap box words ...
KCStudly wrote:Something to keep in mind ... But then again if it is raining that hard you will likely close the hatch.
KCStudly wrote:Any thoughts on the chosen size of the gutter (arbitrary based on available alum.?) and have you given any thought to pitching it toward either side?
KCStudly wrote:Maybe I'm over thinking things, as usual.
capnTelescope wrote:ryuandwings wrote:]2. You may want to look into something like "F" shaped channel instead of making gutter from 2 angles. I still don't know how to turn the corner, but F shaped trim should give you a channel for water with a flange for mount.
That would be convenient. Do you have a source? I've only started looking for stock aluminum shapes. I'm looking for a 1" high, 1" wide (maybe 1=1/2"?)gutter. I used 2 pieces of angle because that's what HD had today.
ryuandwings wrote:I was thinking something like this.
http://www.brunnerent.com/Tools/Portfol ... trMetaTag=
tony.latham wrote:Sometimes it's the journey, not the arrival that pricks our lives, and that's where you're clearly at with this project.
tony.latham wrote:Your posts are much more interesting than the show, "How It's Built."
KCStudly wrote:Something to keep in mind that has tripped up plenty of people, water doesn't just run down hill like one might tend to expect (like Kahn in the Star Trek movie, that's "two dimensional thinking"). It can have momentum from falling or rolling down in a stream, and can run up hill when redirected, or be wind driven directly and/or by vortices. Might be worth a mock-up wet test to be sure that water running off of the roof doesn't shoot past the lower rear lip of the gutter. But then again if it is raining that hard you will likely close the hatch.
RandyG wrote:Too bad you don't have a metal brake...
RandyG wrote:Keep up the tinkering, love it!
GuyllFyre wrote:I am completely enjoying this thread.
Thank you.
