I've been busy piddling with The Big Pink... still working on mounting the wings and adding an air conditioner. The door I bought turned out to be smaller than the description said it was
, so I ordered a different door. I'm building a shelf to mount the AC through the side wall. The front wall has too much curve to it. details to follow...
added some pinstripes
Finally finished bolting the TD to the trailer, no pictures , but I had to bolt the rear half of the trailer to the frame. The front had a coupla bolts and the dropdown floor to hold it in place, but the rear of the trailer was moving sideways about a 1/2 " total.
and I'm working on a rear bumper... found these "shock mounts" in the trash. They match up to the holes in the trailer frame perfectly. I have a piece of 2" square aluminum tubing I may use as the actual bumper, or I might make one of wood (if it doesn't look too cheesy)
