Washington Build Code name Gumdrop
Postby Lambertdarr » Sat Nov 15, 2014 6:41 pm
I have started my build from scratch and so far it has been going well. I have a good start on things and appreciate any comments or suggestions. I am still in the structural phase so I can still implement any hair brained ideas anyone has. I am a hobbyist woodworker that loves a challenge!!!
126273
126272
126271
126270
126269
126268
126267
126266
126265
126264
126263
126262
126261
126260
126259
126258
126257
126256
126255
126254
126253
126252
126251
126250
126249
126248
126247
126246
Lambertdarr
Images: 100
Re: Washington Build Code name Gumdrop
Postby Lambertdarr » Sat Nov 15, 2014 6:57 pm
Does anyone know why only the first 3 pictures show up as images in the post and the rest are links?
Lambertdarr
Images: 100
Postby noseoil » Sat Nov 15, 2014 8:25 pm
I use photobucket & enter the actual image link in a thread. Your images with links are web addresses (http.....) not the image files. Look at the "sharing" part you've posed from and see if there isn't a different type of link to use from the menu choices.
137905
noseoil
Images: 670
Postby pchast » Sat Nov 15, 2014 9:29 pm
I looked at your gallery and now I wonder what your plan is for venting
humidity. We blow out a lot of moisture with our breath that needs
some relieving.
:thinking:
pchast
Images: 97
Postby Lambertdarr » Sat Nov 15, 2014 9:43 pm
pchast wrote:I looked at your gallery and now I wonder what your plan is for venting
some relieving.
:thinking:
The window and the door both have sliding windows. I am also planning on framing in for a roof vent and assess if the ventilation is insufficient. I imagine I will end up putting in a fantastic fan
Lambertdarr
Images: 100
Inside cabin
Postby Lambertdarr » Wed Nov 26, 2014 2:04 am
Almost compete with insulation other than the hatch
Totally finished with the cabinet frames in the front. The Cherry came out fantastic, Now to trim in walnut and to figure out stain
gallery/image.php?album_id=3768&image_id=126562
The little pocket in the pictures have a cigar electrical adapter in the back of each with usb chargers for cell phones. There is one on each side
gallery/image.php?album_id=3768&image_id=126564
Small shelf on the very top of the cabinet for little stuff like flashlights, books, etc It runs the enire length of the shelf
Rear shelves also in cherry. two top cabinets wil have sliding doors yet to be installed, the bottom one will have custom built boxes 3 on each side of the divider for clothes
Lambertdarr
Images: 100
Postby KCStudly » Wed Nov 26, 2014 7:31 am
That is looking very fine, indeed! :thumbsup:
Just a heads up. Did you build the vent fan frame to match the screw pattern of a known fan? Despite the 14 inch standard size, and most people suggesting a 14-3/8 to 14-1/2 inch rough opening, what I found on my Maxx Vent brand fan is that the factory screw hole pattern is a bit wider still. This prompted me to use 2x2 surrounding my fan. you may want to take a closer look at this now, if you haven't already, to make sure that your vent fan screws will find wood.
I'm not familiar with other fan options. I suppose some do not come with the holes already in them, but if they do it would be worth looking into. 1x on edge isn't really a very big target.
Again, you are doing very nice work there! :thumbsup:
Postby Lambertdarr » Wed Nov 26, 2014 11:00 am
Good call. You saved me a good deal of cussing and screaming. I will double up on those
Lambertdarr
Images: 100
Postby lrrowe » Wed Nov 26, 2014 4:45 pm
KCStudly wrote:That is looking very fine, indeed! :thumbsup:
I just installed mine with 1x4" pine boards in a 14 1/2 x. 14 1/2 inch square. And I just noticed that two screws missed the wood frame. Darn. No leaks however. I will reinstall those two screws with a slight angle so as to install into the wood.
So I agree. Use wider boards.
Bob
lrrowe
Images: 439
Postby Lambertdarr » Mon Jan 05, 2015 11:58 am
So, after finally figuring out how to do the water tank I have been able to complete the framing out of the upper cabinet along with the roof to that point. I have the hurricane hinge installed on the roof side just to see if it would fit properly!! The fridge is in and wired the counter raises up there for access inside. I cut a panel to hide it and keep it looking classy! I have to do the cherry veneer which i should start soon but wanted to get as much as possible done so that I could do all the veneer at once! After that it is the trim work and figuring out how I want to stain and seal all of it!! I have not figured out exactly where I am going to put the 12 volt ports, the 115 volt plug and the light switches
127626
127627
127628
127629
Lambertdarr
Images: 100
Postby Lambertdarr » Mon Jan 05, 2015 12:16 pm
I have all the Cherry done!! Now the walnut trim!!! It is going well!! To be honest my girlfriend cut and installed most of it!!
127619
127620
127621
Lambertdarr
Images: 100
Postby KCStudly » Mon Jan 05, 2015 12:21 pm
Looking very nice! I like the built in fridge. :thumbsup:
Postby tony.latham » Mon Jan 05, 2015 12:40 pm
:thumbsup: Sweet looking Bennie! KC gave you good advice on the framework for the Fantastic Fan. I assume you've got it wired too? (The wires should be available at about the 10 o'clock position on the fan, looking from the galley.)
Postby lrrowe » Mon Jan 05, 2015 12:52 pm
Lambertdarr wrote:So, after finally figuring out how to do the water tank I have been able to complete the framing out of the upper cabinet along with the roof to that point. I have the hurricane hinge installed on the roof side just to see if it would fit properly!! The fridge is in and wired the counter raises up there for access inside. I cut a panel to hide it and keep it looking classy! I have to do the cherry veneer which i should start soon but wanted to get as much as possible done so that I could do all the veneer at once! After that it is the trim work and figuring out how I want to stain and seal all of it!! I have not figured out exactly where I am going to put the 12 volt ports, the 115 volt plug and the light switches
127626
127627
127628
127629
I like your galley. For the water, how do you easily replace the 5 gal. container when empty? It appears you have added a connection/pipe to the bottom of it. Is the downpipe flexibe which allows you to maybe turn the container sidways as you screw on the connector?
Bob
lrrowe
Images: 439
Postby Lambertdarr » Mon Jan 05, 2015 1:01 pm
tony.latham wrote::thumbsup: Sweet looking Bennie! KC gave you good advice on the framework for the Fantastic Fan. I assume you've got it wired too? (The wires should be available at about the 10 o'clock position on the fan, looking from the galley.)
I did add the extra width for the fan but I have not installed it. I just framed it in and covered it up. I figure I will install it the first night we sleep in it and it ends up being the amazon rain forest inside the Drop but right now I am under the misconception that I will be able to manage the moisture with 2 windows
Lambertdarr
Images: 100
Users browsing this forum: jdeleon and 3 guests
