fiberglassing td body
Postby doug hodder » Sun May 28, 2006 9:23 am
Gaston...wow!!!...and what a slick approach to fenders for that molded in look....did you have some sort of pattern or just cook up your own design...taillight recesses too, at least that's what I think that spot is on the rear top of the fender.......really nice!!! :thumbsup: Doug
Postby Steve_Cox » Sun May 28, 2006 9:43 am
Chucklehead,
There you go, the ultimate in glasswork on a custom Teardrop. When you started this thread it made me think of Gaston, and I was wondering how his project was going. Gaston, that is really cool, you are an artist in your own right. :thumbsup:
Steve_Cox
Images: 196
Postby Gaston » Tue May 30, 2006 10:54 pm
Hi Doug
No pattern I just glued up a stack of foam and sanded off anything that did'nt look like the fender I had in mind. The fender is easy compaired to making the compound curve PT Cruiser taillamps fit!! then all I had to do was make a mirror inage for the other side. glue it to the foam sides and start glassing. nothing to it :?
The difficult we do now... the impossible takes a little longer
Gaston
Images: 98
Postby SpeedWagon » Wed May 31, 2006 8:11 am
Hello Gaston
How compatible is the pink Styrofoam insulation and the epoxy fiberglass?
From what I understand the fiberglass resin will attack the styrofoam, if it makes contact.
I would hate to see anything bad happen to those fenders.
Dave
SpeedWagon
Postby kirtsjc » Wed May 31, 2006 6:54 pm
Gaston wrote:heres what I'm doing with foam board,epoxyand fiberglass. fender is all carved pink foam then glued to the side with epoxy. the whole thing is covered with biaxial mat, 2 layers of glass and epoxy. then its sanded ,filled with bodyfiller and primed.
WOW! When are you going to be ready to take orders for the second you are going to build like that?
kirtsjc
Images: 43
Postby Gaston » Wed May 31, 2006 8:06 pm
most all the insulation foams are ok with epoxy resin but it drives the price of the build way up there!! if You can find the tan urethane foam you can use polyester resin (much cheaper) but the urethane foam "dusts" (the outer layer of particles come off in shear and the glass doesn't adhear well)... And NO I'm not taking orders. This is a "one off" proof of concept . The finished cost will be around $5000 (at least thats my budget) and the man hours are priceless :? About 50 hrs per side so far
BUT I'll tell you how to build one it you want to try it
Gaston
Images: 98
Postby kirtsjc » Thu Jun 01, 2006 6:26 am
Gaston wrote:And NO I'm not taking orders. This is a "one off" proof of concept . The finished cost will be around $5000 (at least thats my budget) and the man hours are priceless :? About 50 hrs per side so far
Oh bummer! :cry:
I really wanted to buy one of those...
I will wait for your build journal so everyone can have the procedure/methods.
Thanks!
kirtsjc
Images: 43
Postby PaulC » Thu Jun 01, 2006 6:31 pm
Hi CH69, Welcome to the forum. Great to see yet another rough wheeler on board. I've built a modified Benroy Offroad design but do have 31x10x15 wheels and tyres fitted to it. Check my album for pics to give you an idea of what BIG wheels will look like on yours. When matching your vehicle you will find that they look huge on the trailer. My number 2 will have slightly smaller fitted.
Cheers
Paul :thumbsup:
PaulC
3rd Teardrop Club
Images: 36
