Gaston wrote:heres what I'm doing with foam board,epoxyand fiberglass. fender is all carved pink foam then glued to the side with epoxy. the whole thing is covered with biaxial mat, 2 layers of glass and epoxy. then its sanded ,filled with bodyfiller and primed.
Gaston wrote:And NO I'm not taking orders. This is a "one off" proof of concept . The finished cost will be around $5000 (at least thats my budget) and the man hours are pricelessAbout 50 hrs per side so far
BUT I'll tell you how to build one it you want to try it
