6X12 TA V-nose project
Re: 6X12 TA V-nose project
Postby wtcreaux » Tue Mar 24, 2015 12:27 pm
After using the trim router
129799
thanks to the one (sorry I don't remember name) who mentioned using palm sander between coats. Used MinWax polyurethane stain (combo).
129798
wtcreaux
Images: 211
Postby chasg1 » Tue Mar 24, 2015 5:26 pm
wtcreaux wrote:
chasg1 wrote:step by step if you could.
how did you install the window on your door. sealant, etc.. looks easier than putting in an rv window???
The windows (walls and door) were installed at the factory. However, they leaked and caused rust as they had been sealed with caulk. I stripped everything done and used butyl rubber tape. The pictures above are from adding a total of 2" insulation requiring cutting new plywood to allow for the windows.
Hmm.......not good. So is the window in the door an ordinary "house" window and installed the same way except for no outer trim???
thanks
chasg1
Postby wtcreaux » Tue Mar 24, 2015 7:32 pm
thanks
When I pulled it out, there is a trim ring on the inside that screwed into the frame......it looked like a bathroom window out of a mobile home.....
I have also used vertical windows in a 7x14
104971
104969
Word of advice......I used a sawzall for this opening since I was off-site and had left my sabre saw at home.......I should have waited.....
wtcreaux
Images: 211
Postby wtcreaux » Tue Mar 24, 2015 7:38 pm
I used 6' vertical E-track cut to fit. The bottom rests on top of the 6" baseboard, with 1 side being screwed into the metal studs......successfully I might add without screwing into any wires..... :worship:
129822 129821
wtcreaux
Images: 211
Postby wtcreaux » Fri Mar 27, 2015 10:52 pm
External lights
bow
129987
stern
129988
passenger work (27W, cool)
129989
passenger mellow (10w, warm)
129990
driver "bump in the night" (10w, warm)
129991
wtcreaux
Images: 211
Postby wtcreaux » Sat Mar 28, 2015 1:44 pm
I had originally used the light-weight aluminum warning plate for my backplate............it was too flimsy.......ended up buying an aluminum plate at Home Depot. Then cut to size.....
130000 130001
looks more sturdy.......however, I had to add 2 layers of ⅜" plywood to give enough back room for the wires and connectors
wtcreaux
Images: 211
Postby wtcreaux » Fri Apr 03, 2015 8:21 pm
Electrical panel
130172
Center is the PD4045 http://www.amazon.com/gp/product/B002XRU6FM/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
Top Left is surge protector http://www.amazon.com/gp/product/B0050EGS5W/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1
Bottom left is remote switch for inverter http://www.amazon.com/gp/product/B002W87JNO/ref=oh_aui_detailpage_o03_s01?ie=UTF8&psc=1
Far right is remote meter for Morningstar solar controller http://www.amazon.com/gp/product/B007TNT1LK/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
This is in the V of the nose, towards ceiling. I miscalculated the vent fan placement, so it sits ~ 4" in front of the electronics. The wires below the shelf will be covered with an upright panel which will also house a 120v outlet.
wtcreaux
Images: 211
Postby wtcreaux » Sat Apr 04, 2015 4:28 pm
Started on the side table, counter height
130227
The plan was to put the 12v cooler on the floor but thanks to input from members, decided to put on roller shelf.
130228
By raising the cooler, this allowed me to place the battery under the shelf, thereby closer to the axles
130229
you can see the battery in the back. The slides are these http://www.amazon.com/gp/product/B00B511DK4/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1
Then put the 2nd coat of this http://www.homedepot.com/p/Henry-687-4-75-Gal-Enviro-White-Roof-Coating-HE687406/202091034?MERCH=RV-_-rv_nav_plp_rr-_-NA-_-202091034-_-N......yep, expensive. But after the 1st coat, I could tell a huge difference.....the sun had been shining for over 6 hours with the ladder racks being warm to touch but the roof was still very cool to touch.
130230
I plan on putting 4 coats on. I haven't any made a dent in how much I've used (after 2 coats). Appears to be sealing everything......
wtcreaux
Images: 211
Postby wtcreaux » Tue Apr 07, 2015 1:41 pm
Decided to beef up the support on the rolling shelf and provide a stop at the same time......used a 1" x 2" angle strap from Home Depot cut to length
130386
smoothed off the corners
130387
One problem with a rolling shelf is movement during travel. Used a 16p nail at a downward angle to keep in
130391 130390 130389 130388
You can see that not only does the nail block the wood but also the metal slide. The nail point was clipped and filed smooth.
wtcreaux
Images: 211
Postby desertrat222 » Tue Apr 07, 2015 2:55 pm
i need to mount some solar to my radius roof, ALUM is very expensive, what did you use to try and coat / protect this 2x1 steel?
thanks
wtcreaux wrote:Started on the side table, counter height
130227
130230
desertrat222
Postby wtcreaux » Tue Apr 07, 2015 5:15 pm
[quote="desertrat222"]i need to mount some solar to my radius roof, ALUM is very expensive, what did you use to try and coat / protect this 2x1 steel?
thanks
The ladder racks came with the trailer.........I already have rust on them with rust draining from the bottom......... I plan on wire brushing, then rattle can Rust-o-leum..........
wtcreaux
Images: 211
Postby rebapuck » Wed Apr 08, 2015 12:23 am
Nail stop is an efficient idea. Just don't lose the nail. Maybe have another hole to store it in. Or tie a line on it.
Judy
1966 VW camper
1967 VW singlecab
rebapuck
Postby wtcreaux » Wed Apr 08, 2015 9:18 am
rebapuck wrote:Nail stop is an efficient idea. Just don't lose the nail. Maybe have another hole to store it in. Or tie a line on it.
Judy,
Good idea.....think I'll use some fishing line.....
wtcreaux
Images: 211
Postby wtcreaux » Thu Apr 09, 2015 8:32 pm
Had to figure out a way to keep from getting locked in on the barn doors.....
130477 130478
decided to use the trick from others on the side door.......Used a stainless steel eye-bolt, drilled through, added caulk, you can see it to the L of the lock
130480
the eye-bolt is to the L of the handle
130479
Used a ½" bit to open the hole for the lock shank
130481
final product - with the cam locked in this position, the doors still open from the inside. Will use a barrel bolt on the inside to "secure" from the inside....
wtcreaux
Images: 211
Postby wtcreaux » Fri Apr 10, 2015 1:40 pm
Decided against the barrel bolt and used a hook and eye closure........
130492
wtcreaux
Images: 211
