thanks to the one (sorry I don't remember name) who mentioned using palm sander between coats. Used MinWax polyurethane stain (combo).
wtcreaux wrote:chasg1 wrote:step by step if you could.
how did you install the window on your door. sealant, etc.. looks easier than putting in an rv window???
The windows (walls and door) were installed at the factory. However, they leaked and caused rust as they had been sealed with caulk. I stripped everything done and used butyl rubber tape. The pictures above are from adding a total of 2" insulation requiring cutting new plywood to allow for the windows.
chasg1 wrote:
Hmm.......not good. So is the window in the door an ordinary "house" window and installed the same way except for no outer trim???
thanks
wtcreaux wrote:Started on the side table, counter height
Then put the 2nd coat of this http://www.homedepot.com/p/Henry-687-4-75-Gal-Enviro-White-Roof-Coating-HE687406/202091034?MERCH=RV-_-rv_nav_plp_rr-_-NA-_-202091034-_-N......yep, expensive. But after the 1st coat, I could tell a huge difference.....the sun had been shining for over 6 hours with the ladder racks being warm to touch but the roof was still very cool to touch.
I plan on putting 4 coats on. I haven't any made a dent in how much I've used (after 2 coats). Appears to be sealing everything......
rebapuck wrote:Nail stop is an efficient idea. Just don't lose the nail. Maybe have another hole to store it in. Or tie a line on it.
