Mark's Weekender-XL, W/ the magical sliding bed
Postby Gold5one » Wed Apr 01, 2015 7:37 pm
I want everyone to see how my latest idea worked out-- the sliding bed. With no previous plans, I figured this out in about 30 minutes, when out of curiosity, I pulled the mattress forward, up to the counter to see, if I liked the bed in that position.
Then it hit me in an instant-- a sliding bed is what I need. :thinking:
So, I built a sliding bed in order to have a night time porta potti space, and then I cover it up in the daytime.
I gained 3ft of space in the rear at night, then I transferred that 3ft of space to the front of the camper in the daytime. Another advantage is the window A/C won't be so close to the bed. Have you ever seen this done before? What do you think?
Mark
- slide forward for the night-
slide back in the morning-
night time-- bed moves forward to reveal the porta potti.
easy access to the potti at night-
bed slides to cover up the potti in the daytime-
the wall rail- ripped from a 2x3.
The the bed frame slide track on the wall - I will screw a small strip on the wall above the bed frame, so it doesn't bounce out of the track on the road.
Mark
viewtopic.php?f=50&t=74522
Weekender-XL build journal
sold-2018
Gold5one
Images: 157
Re: Mark's Weekender-XL, W/ the magical sliding bed
Postby Alfred » Wed Apr 01, 2015 10:04 pm
My Weekender-for-5 has a sliding bunk. See links for pictures/video below!
Al in Asheville
Alfred
Images: 368
Postby Gold5one » Wed Apr 01, 2015 10:47 pm
Alfred- you really did need the extra room! I'll bet you could fit 2 adults and 5 kids in my build. I was thinking about adding an overhead bunk for a teenager-- do I have enough room? ( 66" inside width).
Mark
sold-2018
Gold5one
Images: 157
Postby rebapuck » Fri Apr 03, 2015 1:21 am
Potty with a view.
Judy
1966 VW camper
1967 VW singlecab
rebapuck
Postby Gold5one » Fri Apr 03, 2015 10:01 am
Since I am traveling solo, I don't need potti closet.
There will be a 5000 btu ac in that window- maybe by next week.
added: I checked the forecast here- it will be 90 degrees on Sunday- We have 2 seasons here-- a 70-80 degrees winter and 85-95 degrees summer. :icedtea:
So, I am working on installing the A/C today!- then a test run later with my 800W generator to see how many hours a tank of gas lasts.
Mark
sold-2018
Gold5one
Images: 157
Postby Gold5one » Fri Apr 03, 2015 3:05 pm
5 hours later-- A/C is in-- the potti with the low picture window is no more. :oops:
Mark
sold-2018
Gold5one
Images: 157
Postby ZaraKaine » Wed Jul 22, 2015 2:32 am
I like the bed and your work...but can you please give more details how did you make this bed step by step!
Surf the best bedspreads online in Australia for shopping.
ZaraKaine
Postby Gold5one » Sun Jul 26, 2015 7:40 pm
I used a 1x3 for the sides of the bed frame and 2x2 for the cross members. The 2x2 is flush with the top edge, leaving a lip that can slide in the grooved board on the wall. I"ll post a few more pictures if the rain stops tomorrow.
Mark
sold-2018
Gold5one
Images: 157
Postby Gold5one » Mon Jul 27, 2015 3:30 pm
I hope these pictures help. The bed weight slides on the 2x2's- use bar soap or paraffin to help it slide. 2x2's are on 12" centers, but use your own judgment for spacing- this is a single wide bed. I doubt that you could slide a wider bed.
you must screw a short plywood strip to the wall above the 1x3, so it stays in the track going down the road.
Mark
sold-2018
Gold5one
Images: 157
