Weather stripping
Re: Weather stripping
Postby OP827 » Tue Apr 21, 2015 8:25 pm
KCStudly wrote:
My $.02... and this is purely intended to imply that you are a braver man than I... I would be much more likely to build a lifting roof with a cofferdam, like Sharon's MyAway, but would probably stick with soft sides like Mike Young's build. In fact, if I do ever build a second it might even be a trolley top slouchy, or even full standy. But then again, towing efficiency isn't my biggest concern.
Long ago I've decided to do this build as an experiment of something that was not done before and see what happens as I go. As you could see even the conceptual design has changed since I started the build, because I found things I did not think of before. I am not afraid of failures, I learn from them. This build is a journey, but I would like to finish it sometime sooner rather than later and go testing, sorry, I mean camping. :)
OP827
Images: 414
Postby KCStudly » Tue Apr 21, 2015 8:49 pm
Cool. :thumbsup:
Postby OP827 » Wed Apr 22, 2015 3:32 pm
KC, for side filling wall the seal would look something like that, right?
OP827
Images: 414
Postby OP827 » Wed Apr 22, 2015 3:50 pm
And with the roof down it would be like this:
OP827
Images: 414
Postby OP827 » Wed Apr 22, 2015 4:18 pm
Except for one thing on the above: I would put the hinge inside the juncture... forgot about that, i need this to look neat :) .
OP827
Images: 414
Postby KCStudly » Wed Apr 22, 2015 4:58 pm
Nice sketch. I think I would put the seal right toward the weather side and avoid the extra cut. Keep the water out, all the way out. Also, no groove for water to settle into; would just spill out.
Postby OP827 » Wed Apr 22, 2015 5:24 pm
KCStudly wrote:Nice sketch. I think I would put the seal right toward the weather side and avoid the extra cut. Keep the water out, all the way out. Also, no groove for water to settle into; would just spill out.
So it would become very similar to Winter Warior seal sketch above, except for D-cell seal, right?
OP827
Images: 414
Postby KCStudly » Wed Apr 22, 2015 6:43 pm
This is more like what I have been thinking; outside is to the right. It's just fewer cuts and with the seal stuck to the upper piece you still get the lip on the lower section that water would have to climb (if it got by the seal).
It might be worthwhile to study the WW plans further; search for related threads; and even PM angib to make sure that there was not some other legitimate reasoning for the double step (zig-zag) joint. Like I said, all I can think of is that it forms a bit of a "key" to, in theory, stiffen the wall, relying less on the hinge.
But again, I have not studied the design in detail.
Postby OP827 » Wed Apr 22, 2015 7:12 pm
Got it, thanks for your help KC.
OP827
Images: 414
