KCStudly wrote:
My $.02... and this is purely intended to imply that you are a braver man than I... I would be much more likely to build a lifting roof with a cofferdam, like Sharon's MyAway, but would probably stick with soft sides like Mike Young's build. In fact, if I do ever build a second it might even be a trolley top slouchy, or even full standy. But then again, towing efficiency isn't my biggest concern.
Long ago I've decided to do this build as an experiment of something that was not done before and see what happens as I go. As you could see even the conceptual design has changed since I started the build, because I found things I did not think of before. I am not afraid of failures, I learn from them. This build is a journey, but I would like to finish it sometime sooner rather than later and go testing, sorry, I mean camping.
