Woodie build
Woodie build
Postby wiseguydirk » Mon Jun 01, 2015 1:29 pm
Here is our woodie style build all custom no plans. it has insulation in the walls, floor ,and roof 5x8' overall with 6' being inside sleeping area and the back opening up to a 2' full kitchen. It has a bar sink, upper cabinets and lower drawer pullout for both a cooler and a camp stove.
Full 30amp shore power and water hookup, 120v on demand hot water tank. Trailer is wired with both 12v and 120v it has led exterior lighting with interior led lighting for both sleeping area and kitchen.. 12v outlets and 120v outlets
The build process was long, we started with an old U built trailer from 1988.
We started April 2014 and we're still working on it almost a year later.
I'll start posting the photos of the whole process soon
The first step was hunting down all the materials I had drawn up a sketch early in the process after looking at a few teardrop trailers on pintrist
The old frame was in rough shape. I cleaned it up and painted it..
Here is a picture of the walls being built. In traditional building fashion we built them from the inside out. 1"1/2 styrofoam on the inside with 1x2 studs and tuck tape and staples and glue to hold it together.
wiseguydirk
Re: Woodie build
Postby daveesl77 » Mon Jun 01, 2015 4:32 pm
Nice looking woodie! I'm still in the process of "finishin'" mine.
dave
daveesl77
Images: 273
Re: Woodie build
Postby Juneaudave » Mon Jun 01, 2015 7:11 pm
Congratulation!!!! I'm sure you will be giving a lot of tours while traveling! :applause:
Juneaudave
Images: 380
Re: Woodie build
Postby Woodbutcher » Mon Jun 01, 2015 7:45 pm
Beautiful trailer! Good job. :beer:
Woodbutcher
Re: Woodie build
Postby noseoil » Mon Jun 01, 2015 8:39 pm
Nice design, simple & clean. Really like the lines. Great job on the build.
137905
noseoil
Images: 670
Woodie build
Postby wiseguydirk » Mon Jun 01, 2015 10:48 pm
Here is the start of the arc. We had to redesign it twice to get the correct radius to look just right.
We ripped some 12' 2x6's into 1/4 inch strips that we bent, epoxied, and stapled into place.
Both side panels were pre wired for 12v switching and switch legs to be later run through the floor and roof.
After we had the panels built and wired we went on to building the floor which had its own set of challenges. I opted to have the floor insulated and raised up, and under coated. I'll show how it washers jalna.bjshks jdnxushahsmd
wiseguydirk
Woodie build
Postby wiseguydirk » Tue Jun 02, 2015 3:02 pm
The next step was adding a type of flashing moulding to where the frame met the plywood floor. It was a fairly easy process except for having the walls attached, lowering the ,j duibsilybdiylbdn jdknjxjonsojnsnjo jdjxjxhsahs
wiseguydirk
Woodie build
Postby wiseguydirk » Wed Jun 03, 2015 4:43 pm
After the plywood base had been bolted down using stove bolts, the walls were put together. A fairly easy process when they're pre built.. And ready to go. all the wires pre wired hanging out ready for the boxes to be cut out. Kdmdindhvaaydkdiemc jihadists jdkdkxndjz
wiseguydirk
Re: Woodie build
Postby dogscats » Wed Jun 03, 2015 7:41 pm
I will hold my breath .More about the out side looks great
TODAY IS THE OLDEST YOU'VE EVER BEEN,
YET AT THE SAME TIME, THE YOUNGEST YOU'LL EVER BE,,, SO MAKE THE BEST OF IT WHILE YOU CAN, AND ENJOY THIS DAY WHILE IT LASTS
dogscats
Images: 20
Woodie build
Postby wiseguydirk » Wed Jun 03, 2015 8:46 pm
Here is the floor framed up 1x2 with foam insulation. Low voltage wires notched into the floor and tuck taped down. Everything had to be pre planned with the running lights, exterior lights, inside light, kitchen light and switches
The running lights were run to a central location close to the front to later be run into a box then connected to a female 6 dkdosoxoxkxoxoxox dkdkdkd
wiseguydirk
Woodie build
Postby wiseguydirk » Wed Jun 03, 2015 8:54 pm
Q
wiseguydirk
Woodie build
Postby wiseguydirk » Thu Jun 04, 2015 8:50 pm
The wiring worked out great here. It all came together with the construction of the kitchen wall. Lino and everything worked out great.
Low voltage wiring and 120v wiring separated in wall and ran to the designated locations..
Kitchen mock up rough plywood and counter top installed.
Dodos,skskz
wiseguydirk
Woodie build
Postby wiseguydirk » Fri Jun 05, 2015 12:20 am
Waste ,Xmas ok lid lid. Lick lk DJ lid kl
wiseguydirk
Woodie build
Postby wiseguydirk » Fri Jun 05, 2015 12:24 am
Trew
wiseguydirk
Woodie build
Postby wiseguydirk » Fri Jun 05, 2015 12:26 am
If you want to go down this route all I can say is good luck. So much time was spent using epoxy and clamping to make this arc.. I have seen a lot of people try and do angles and lap joints, but it doesn't come out as smooth..
My initial idea was to get a PVC deck board heat it up and bend it around a jig.. This would have made water proofing a lot easier. Adding this trim also made the trailer larger than 5'. So if you know about the aluminum trim this makes it a lot harder to get a proper seal. I
wiseguydirk
