Gally Counter top. What did you use?
Postby tearbum67 » Wed Sep 19, 2007 6:19 pm
Im makeing good progress on the "Land Ark" (Ineed to put some updated photos in my album). Im get close to building the lower gally cabinets and Im wondering what others of us have used. Im thinking probably Plywood? :roll: If so did anyone cover it w/ ? Tile, Vinyl...? Just wondering and looking for ideas. Thanks :?
If it dont fit, Force it!
tearbum67
Images: 36
Re: Gally Counter top. What did you use?
Postby Classic Finn » Wed Sep 19, 2007 6:33 pm
tearbum67 wrote:Im makeing good progress on the "Land Ark" (Ineed to put some updated photos in my album). Im get close to building the lower gally cabinets and Im wondering what others of us have used. Im thinking probably Plywood? :roll: If so did anyone cover it w/ ? Tile, Vinyl...? Just wondering and looking for ideas. Thanks :?
Hi there and greetings from Scandinavia..Great progress on your build.. :thumbsup:
Here is a photo of our countertop.. Its mahogany..and 2 coats of wax.
Classic Finn ;)
Classic Finn
Midnight Sun Voyager
Images: 146
Postby asianflava » Wed Sep 19, 2007 7:51 pm
The same sandwich panel I used for the floor, walls, cabinets, bulkheads, etc. 1/8 birch ply - 3/4 framing and insulation - 1/8 birch ply
asianflava
Postby martha24 » Wed Sep 19, 2007 8:20 pm
tearbum,
We glued Formica on 3/4" plywood. For the old look we used aluminum counter top edging we got at Lil Bear.
Martha ;)
Martha ;)
martha24
Images: 237
Postby Gerdo » Wed Sep 19, 2007 8:33 pm
I used a premade formica countertop from HD. It is what I had. If it doesn't last I'll just replace it with something at that time. So good so far. It's holding up well even thouugh it has gotten wet a few times.
Gerdo
Images: 156
Postby halfdome, Danny » Wed Sep 19, 2007 9:09 pm
I used scrap plam left over from a job with curly Maple for the edge. Did the back splash and tear walls in the galley area with it too, very easy to keep clean. :) Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby b.bodemer » Wed Sep 19, 2007 9:27 pm
I went with tile.
So far so good!
Barb
b.bodemer
Images: 328
Postby tearbum67 » Thu Sep 20, 2007 6:21 am
Classic Finn
That is beautiful!!! :thumbsup:
Classic Finn ;)
tearbum67
Images: 36
Postby MrBuzz » Thu Sep 20, 2007 11:02 am
For the countertop on my TD I built the main shelf using 3/4" plywood and joined it to the other bulkhead pieces for strength. Then I used some leftover oak-finish click together laminate flooring to cover the plywood. I looked into a formica countertop but it's pretty heavy and expensive for the small piece I would need.
Generic Benroy - built 2007, 4X8, 1175 HF trailer, Structoglass roof and headliner, 12v and 110v electrics with Schumacher charger.
MrBuzz
Images: 77
Postby doug hodder » Thu Sep 20, 2007 10:34 pm
Stainless in the first 2...formica in the last one...with a scuff pattern on the stainless it hides a lot. Doug
Postby john » Thu Sep 20, 2007 10:40 pm
I used some some prefinished hardwood flooring.
It was some kind exotic wood Lowes or HD was unloading cheap (15-20 bucks a box).
Build I -- Scenic ---
http://www.flickr.com/photos/8121727@N04/
Goto the Tear Build file
Build II -- Scenic II ---
viewtopic.php?t=29603
Build III -- Scenic Solo---
viewtopic.php?f=50&t=50324
Travel Blog----Now without Political Commentary
http://polifrogblog.blogspot.com/2009/0 ... -2009.html
The Constitution was ratified, not an interpretation thereof...
Penomeli ikibobo
john
john
Images: 261
gally counter
Postby tearbum67 » Fri Sep 21, 2007 10:32 am
doug hodder wrote:Stainless in the first 2...formica in the last one...with a scuff pattern on the stainless it hides a lot. Doug
Very very nice!! :applause: :thumbsup:
tearbum67
Images: 36
Postby Classic Finn » Sun Sep 23, 2007 6:49 am
Wow there are some Beeeeeutiful Countertops above.. and the way the galley,s were done.. :applause: :applause: :applause:
The only set back on our countertop is that its heavy... :oops: :oops: And I sort of regret that.
Classic Finn ;)
Classic Finn
Images: 146
Postby BrwBier » Sun Sep 23, 2007 8:23 am
We used formica from Menards, glued to a sandwich of 1/4 ply 1/2 foam board 1/8 ply. We even used the sink cutout for a cover. I made my own wood edge for the front and the back just runs under the cabinets. I think it comes 8'x30" so there was plenty for the table on the inside and a piece for in the drawer. I don't think I had any left over, I just kept looking for places to use whatever size piece I had.
Brwbier
BrwBier
Images: 100
Postby Ma3tt » Sun Sep 23, 2007 9:35 am
I cut up an antique oak top desk
Be Good
1967 Siesta del Sobrino "Standy"
If you lived here... you would be home by now.
http://www.Camp-Cook.com
Ma3tt
Dutch Oven GURU
Images: 179
