Figured with winter coming up I would post how I make the boards as everyone here can easily make there own.
I use 2 X 2 for the framing and miter the corners together.
You will need 4 24 inch pieces
4 48 inch pieces
4 11 1/2 pieces for the legs I cut the top corners off these, and leave about 1/4 inch flat on top
2 18 inch cross members for the legs
I use 2 inch screws and angle them slightly from below.
I use 5/16 3 1/2 toggle bolts with lock nuts the holes are 3/4 inch down from the inside of the top frame rail and 3/4 down the side frame rail.
I use 1/2 oak or birch 4 ft. x 2 ft. the hole is 12 in from side 9 in from top and 6 inch around.
Bags are 6 inch across filled with feed corn made from duck cloth.
I use an exterior high gloss paint and about 7 coats of polycrylic on the top.
I also make tailgaters which is exactly half size of the big ones, the only diff is the hole is 4 inch and bags are 3 since the bags dont have the flex the big ones do.
Here are some pics of some of the boards I haqve made. Any questions about how to make any or were to find different decals etc. feel free to ask.
http://s216.photobucket.com/albums/cc36 ... %20Boards/
