madjack wrote:Dooner, the first one I bought(to prove a concept) had been sabatoged at the factory...somebody and smacked the board with a hammer or????....the second one worked just fine but the cooling fan started making funny noises after a couple of trips...I have switched over to one of these since they are designed to be waterproof, shock and vibration resistant...the vibrations from travelling probably is what caused the fan problems in the B&D charger...the Deltrans is designed to be permanantly mounted and hardwired into the system and according to the technical specs, it is a 4stage charger as well as a switching power supply..................
p.s. I don't have anything paticularly against the B&D charger...it would probably make a great home charger, it is just not what I wanted.........MJ
madjack wrote:Dooner, the unit is meant to be hardwired into the system and plugged in as needed...it will not cause a discharge when not plugged in...it has no switch(that I ever found), just plug it in and fahgitaboutit.......
48Rob wrote:Hi Dooner,
No, never have we experienced interference of any kind, on either side.
We've been very happy with the unit. It does a great job of keeping my two 6 volt golf cart batteries in top shape.
I'll be using the same charger on my next project...
Rob
