Mounting for 12v fuse panel and ground block
Anything electric, AC or DC
Postby dhazard » Thu Feb 07, 2008 7:48 pm
James, I can’t believe that Madjack didn’t add "Please Post Pics of anything you come up with".
Many miles and many tears. Times were hard but now they're changing.
You should know that I'm not afraid.
dhazard
Images: 122
Postby Dooner » Thu Feb 07, 2008 8:04 pm
madjack wrote:Dooner, the first one I bought(to prove a concept) had been sabatoged at the factory...somebody and smacked the board with a hammer or????....the second one worked just fine but the cooling fan started making funny noises after a couple of trips...I have switched over to one of these since they are designed to be waterproof, shock and vibration resistant...the vibrations from travelling probably is what caused the fan problems in the B&D charger...the Deltrans is designed to be permanantly mounted and hardwired into the system and according to the technical specs, it is a 4stage charger as well as a switching power supply..................
madjack 8)
p.s. I don't have anything paticularly against the B&D charger...it would probably make a great home charger, it is just not what I wanted.........MJ
Thanks MJ.
Your opinion is valued greatly. I looked at the product you use, and if you say that would be a better product, I'll get one asaIc. The price isn't bad either. Does it have an on/off switch that has to be turned on to work like the B&D? or can it be set to on so when you connect to shore power, it is automatically on? Having to turn on the B&D every time was the only thing I didn't like about it.
Dooner.
TED NUGENT FOR PRESIDENT!
Dooner
Images: 69
Postby madjack » Fri Feb 08, 2008 12:07 am
Dooner, the unit is meant to be hardwired into the system and plugged in as needed...it will not cause a discharge when not plugged in...it has no switch(that I ever found), just plug it in and fahgitaboutit.......
madjack 8)
Postby Dooner » Fri Feb 08, 2008 11:41 am
madjack wrote:Dooner, the unit is meant to be hardwired into the system and plugged in as needed...it will not cause a discharge when not plugged in...it has no switch(that I ever found), just plug it in and fahgitaboutit.......
madjack 8)
:thumbsup: 8) COOL! That is exactly what I want.
Oh yeah, one more question that I just thought about. :thinking: Have you noticed any interferance with the radio or tv while in use? Either on the 12v side or 120v side?
Dooner.
Dooner
Images: 69
Postby madjack » Fri Feb 08, 2008 9:17 pm
Dooner, since I have no TV and use a little boom box for radio, I can't answer your question BUT, I believe that TonyJ, Rob48 and possibly Danny(and others) all use this setup...they may be able to answer your question...
madjack 8)
Postby Dooner » Sat Feb 09, 2008 10:39 am
Thanks for all the info MJ. Now if these guys will ring in and let me know about any interferance, I'll be on the road to getting a new charger. :D
Dooner.
Dooner
Images: 69
Postby 48Rob » Sat Feb 09, 2008 11:37 am
Hi Dooner,
No, never have we experienced interference of any kind, on either side.
We've been very happy with the unit. It does a great job of keeping my two 6 volt golf cart batteries in top shape.
I'll be using the same charger on my next project...
Rob
48Rob
Postby Dooner » Sat Feb 09, 2008 11:47 am
48Rob wrote:Hi Dooner,
Rob
Thanks for the info Rob. Now, if Tony or Danny doesn't ring in and give a bad report on theirs, I will be getting one very soon. :thumbsup:
Dooner.
Dooner
Images: 69
Postby tonyj » Sat Feb 09, 2008 1:08 pm
Dooner,
No interference of which I am aware. Have noticed none through the radio, and it has gotten the most use. Since I've never hooked up an antenna to the TV, not sure about any interference there, but have noticed none when watching DVD's.
I am on my second charger unit like MJ has. I was never able to determine if the problem I had was charger or battery related, and I replaced both. The charger was just a little over a year old and they replaced it (which I hadn't expected). Since September, I have had no problems.
Like MJ said, no switch on the unit. I opted to leave the plug on mine so I can disconnect it from the outlet when I don't want it on. That came in handy on the first unit because it would go into full charge mode every time I plugged into shore power, overcharging the battery and making those nasty fumes we shouldn't inhale while we sleep. I haven't had that problem with the replacement as it seems to be correctly sensing the charge status of th battery. In lieu of plugging and unplugging the unit, you could hardwire it into a circuit with its own breaker.
All considered, I still give the Deltran a :thumbsup: .
tony
tonyj
Images: 160
Postby Dooner » Sun Feb 10, 2008 11:11 am
Thanks for the info Tony. Sounds like some good reveiws. I'm putting it on top of my shopping list.
I went to the Deltran site to do some reading and found this cool looking battery tender. I'm not saying it is another one to get, because it says do not use in extreme conditions. I just thought it was cool looking.
It is 800Mah with dual battery charger.
http://batterytender.com/popup_image.php?pID=54&osCsid=79cc7eb3e8f030d8c7b2e0ff25f99a35
Dooner.
Dooner
Images: 69
Return to Electrical Secrets
