Where To Start... Where To Start.... :P
Postby Curtis in Texas » Mon Dec 28, 2009 5:31 pm
No, I was talking about the top cover on the roof. It's pointed at the front on the 1500 and blunt on the 1300's or at least they use to be.
I had to reinforce my Pop Up roof frame to support mine too. THey Pop UPs are nly made to support the 1300's.
If it works well you can park in the Mojave in August and make pop sickles in your living room. 8)
Curtis
Curtis in Texas
Finally, a bit more....
Postby SirJoey » Thu Jan 28, 2010 3:55 pm
Had a nice, warm, sunny day, so I finally resumed work on the little trailer today.
First, I built a frame with 14 x 14 ID:
Mounted frame between rear rafters, & drilled 4 corner holes:
Went topside, marked, & cut out with saber saw:
Inserted Fan-tastic roof vent. It fits!
Mounted Camco roof-vent cover:
Voila! Like the A/C, all finished except for the wiring!
Next comes driver-side window & insulation.
When all is said & done...
a lot more gets SAID than DONE!
SirJoey
Postby Prem » Thu Jan 28, 2010 10:44 pm
You da man! Nice work. :thumbsup:
My goal...
...is to live in a trailer.
Prem
Images: 144
Postby synaps3 » Thu Jan 28, 2010 11:44 pm
Where did you find the roof vent cover? One of those might come in handy for my build. :)
-- Dave
Build log: here
synaps3
Images: 254
Postby SirJoey » Fri Jan 29, 2010 8:38 am
Thanx, Prem! Compared to some of the quality work I've seen on here though, I'm just a hack, but I'm givin' it the ol' college try, as they say! :)
Synaps3, after much shopping & comparing prices, both locally & online, I ordered mine here, the cheapest price I could find: http://www.amazon.com/gp/product/B000ED ... e=&seller=
Hope this helps!
SirJoey
Postby SirJoey » Thu Feb 11, 2010 3:03 pm
Installed second window today!
Small steps... :)
SirJoey
Postby Rvankeur » Thu Feb 11, 2010 4:37 pm
SirJoey wrote:
Yeah, that's it... a jet-pack-powered, rolling meatlocker! :lol:
Thanx guys, now I don't feel so bad about spending $300
for a ridiculously oversized AC unit, in the middle of Winter... :crazy:
Saw this today - then read this thread... 8)
http://www.cabelas.com/cabelas/en/templ ... hasJS=true
Rose and Ed
Rvankeur
Postby SirJoey » Thu Feb 18, 2010 3:15 pm
Got the trim piece for the fan cut down to the thickness of the ceiling, & installed:
And the first wall gets the insualtion treatment! Yee-Hah!
Still have to insulate the space in the wall studs, but the first wall is almost finished, insulation-wise.
At this rate, I'll have it finished just in time for the
apocalypse of 2012, when it'll become my permanent home.
:o
SirJoey
Postby Prem » Thu Feb 18, 2010 4:03 pm
I've built every one of rigs for decades with the idea of living in it when the house of cards of society falls down. Still waiting. :SH
My goal...
Prem
Images: 144
Postby glamoree » Thu Feb 18, 2010 4:22 pm
I like what your doing , I am right behind you. I bought a 5x8 in Florida, I am Kentucky and my son is supposed to leave tomorrow (Friday) to bring it up. I am ready to get started. I went shopping @ lowes for the insulation, & I have been looking for windows and doors. So if you dont mind I'll just follow your footsteps here..I have always said I am a cook not a carpenter. I do cook for a living so this should be interesting. Did you put the A/C in yourself?
"Green Lantern Corpsman"
glamoree
Images: 34
Postby southpennrailroad » Thu Feb 18, 2010 6:19 pm
synaps3 wrote:Where did you find the roof vent cover? One of those might come in handy for my build. :)
I installed one of those covers and while I am totally pleased with the cover, I realized this winter that even with an arch (curved) roof, that this slope or curve is not enough to stop water leaking at the sealer around the vent flange. When you install this you will need to make sure the area will not leak or doesn't leak. Facts are that the one foot of snow will not be stopped from entering the vent seal even with this cover on as it leaks while standing still since last November. Getting back to the opening sentence, I will need to remove the cover and remove the old sealer and put on new sealer or eternal bond which is what I am thinking of putting on the vent flange then reinstalling the vent cover.
Long time researching the abandoned South Pennsylvania Railroad along the Pennsylvania Turnpike. God will guide me. As he has done so in the past. southpennrailroad.com
southpennrailroad
Postby SirJoey » Thu Feb 18, 2010 9:49 pm
glamoree wrote:I like what your doing , I am right behind you. I bought a 5x8 in Florida, I am Kentucky.... Did you put the A/C in yourself?
Thanx, Glamoree. KY, huh? I moved here from KY.
As for the A/C, no way. :shocked: FAR too heavy for ME to wrestle with.
See the first few posts on page 1 of this thread...
SirJoey
Hereare some pics of my insulation-completed yesterday
Postby chukar » Fri Feb 19, 2010 1:42 pm
"First question... insulation... some guy told me I should just drill a few small holes in the top of each sheet of plywood, & squirt the walls full of spray-in foam. "
I agree with what someone else said on the expansion factor.
I used 1" Styrofoam with moisture barrier on both sides. I used a couple tubes of liquid nails to stick it to the ceiling and scraps to fill in the edges where the roof bends.
Now I just need to figure the best way to get some luan attached to the ceiling.
Was not as bad a job as I though it might be; about 8 hours for walls and ceiling. Was told to use a serrated knife to cut the foam but found a skill saw was 10 times faster and cut better as well.
Here are some pics:
[img][img]http://www.tnttt.com/gallery/image.php?image_id=61543[/img][/img]
chukar
Images: 32
OT
Postby MegC » Fri Feb 19, 2010 7:38 pm
Like the wirehair you've got in your avatar. :thumbsup:
~ intel gathering until we get more $. If anyone's got a line on a winning lotto ticket or a tooth fairy I can shake down for cash, PM me.
"...believing in human perfectibility starts with trying to force people into a mold, then into a prison, and then into an oven."
MegC
Images: 6
Postby SirJoey » Fri Feb 19, 2010 9:40 pm
The gap in the wall studs:
Wall studs insulated:
Cutout for first electrical outlet:
It's just roughed in... still have to cut a notch in the insulation for inserting the wiring.
SirJoey
Users browsing this forum: Bing [Bot] and 5 guests
