OH, and polyester stinks more for a longer time and will give you a headache if you use it indoors. keeping your significant other happy may be worth the extra money for the epoxy..
synaps3 wrote:I'll be building in a parking garage -- no big deal on the odor thing.
and free can convince the significant other that poly smells great!parnold wrote:OH, and polyester stinks more for a longer time and will give you a headache if you use it indoors. keeping your significant other happy may be worth the extra money for the epoxy..
That's a good tip, but I don't have a significant other anymore, plus I got two gallons of polyester resin given to me as samples since I sell the company's full product line. It's hard to beat free.
well, I've used both a lot over the years an'd I've seen what happens over time. sure epoxy is better but poly is more than good enough so it doesn't really matter if epoxy is better or not. poly will work great for what you want to do. just make sure the wood is dry, you sand shortly before you apply the resin, get all the dust off and follow the instruction for adding the catalyst. it's different that epoxy.. epoxy is a set ratio 1 to 1 or 2 to 1 etc. with polyester, the catalyst has a variable ratio. the more you use the faster it will set but too many people go whole hog thinking if 2 is better than 1, the 3 must be even better and end up cooking the resin. you want to use the least catalyst, not the most for you given situation. the other thing is the unwaxed resin will not air harden and will remain sticky. you'll need to get the wax and add it into the resin on your last coat. the alternative is to get waxed resin but you will have to add the subsequent coats before the last has cured or you'll have to sand first.synaps3 wrote:I'll be building in a parking garage -- no big deal on the odor thing.
synaps3 wrote:
Procedure:
1. Mix poly resin (be minimalistic on hardener)
I use disposable clear plastic cups and mark about 8 oz fill line with a sharpie on each - to get the 8 z fill line use a measuring cup and fill with water to 8 oz and pour into the cup - mark line on cup. Make several of these. Your resin will come with instructions of how many drops of hardener per ounce of resin - just do the math
2. Apply poly resin layer
Can be done with brush or roller - just know that this is a one time use for the roller or brush - I usually use an aluminum pan and small roller to get the job done - later you can break out the cured resin from the pan and reuse the pan again.
3. "Wet out" fiberglass and apply on joints <- Can someone explain this step?
By wetting out - you are saturating the fiberlass and it will turn almost transparent depending on the thickness of the glass matt. If you use FG tape, then just soak what you need for the whole seam in the resin and apply to the seam - thus both sides are saturated - sdmooth out any runs or bubble. Advice: get a box of disposable latex gloves - your hand will thank you
4. Apply more poly resin layers, each time mixing a new batch
5. Apply wax? What type?
The stuff you buy at HD ot lowes does contain wax and you will have to a light sanding between coats
6. Automotive enamel
7. Automotive clearcoat (optional)
Thanks again for all the help!
for the amount you'll need it may be cheaper to go to an industrial supply like the one I posted. by the time you add up the resin, the hardener, the cloth/matt/tape, the mixing pots, brushes/rollers etc you may come out cheaper AND you'll get better quality, fresher resin. at least call around with a list and get quotes. they will also give you expert advice. it's one stop shopping and you get exactly what the pros are using..synaps3 wrote:Wow, thanks for the tips everyone! I wasn't expecting such support, with how many people on this forum preach CPES and epoxy nonstop.
Thanks for the link, afreegreek, but I'm probably just going to buy the Bondo-brand stuff at Home Depot.
What is the exact procedure for applying the poly resin, and fiberglass?
I'll take a stab at it, but can someone clarify a few points, just to make sure I have the procedure right?
Procedure:
Users browsing this forum: Google [Bot], Jimbodub and 1 guest
