Floor/trailer
Floor/trailer
Postby Boanerges4 » Sat Mar 27, 2010 3:16 pm
saw plans on fleabayfor a trailer using only 4x8 sheet of 3/4 plywood with trailer tongue and springs mounted directly to plywood. How sturdy is this, and has anyone else tried it? :roll:
Boanerges4
Postby starleen2 » Sat Mar 27, 2010 4:31 pm
Not me! - Sound a little flimsy to me - no saying that it wouldn't work, but i wouldn't want to try it :roll:
starleen2
5th Teardrop Club
Postby Ageless » Sat Mar 27, 2010 4:47 pm
Well, the Pico Lite is the same way and it's sturdy
http://www.tnttt.com/viewtopic.php?t=34755
Ageless
Postby starleen2 » Sat Mar 27, 2010 8:07 pm
As I read the question - it sounded like the Springs are mounted directly to the plywood instead of a some type of framework - is that right Boanerges4?
starleen2
5th Teardrop Club
floor
Postby Boanerges4 » Sat Mar 27, 2010 8:23 pm
no frame just mounted to plywood. Plans are on ebay. I could understand if it had a 2x4 frame out of wood, but basically all that supports the plywood from sagging is the side walls. :thinking:
Boanerges4
Postby Lou Park » Sat Mar 27, 2010 9:05 pm
I got on ebay to look and see, but I couldn't find descriptions that specific.
Can you post a link? Im curious.
Lou
Lou Park
Images: 5
floor
Postby Boanerges4 » Sat Mar 27, 2010 9:32 pm
Ebay item no. 330417352230 scroll down and read specifics :thinking:
Boanerges4
Postby synaps3 » Mon Mar 29, 2010 10:50 am
I don't see the tongue being connected directly to plywood...
In any case, you NEED a metal trailer frame below the trailer itself. The smallest frame so far is the Pico, which Ageless pointed out earlier.
You don't need a wood frame below your plywood baseboards, unless you want one. My build is on a camper frame, so there is plenty of support from the metal that makes a wood frame below the plywood unnecessary.
-- Dave
Build log: here
synaps3
Images: 254
Postby dh » Wed Apr 07, 2010 10:02 pm
I inherited my grandpa's "Handyman's Encyclopedia" Copyright 1965.
You wouldn't believe some of the crazy trailer designs they have in there. An entire trailer built out of wood, and the axle is made out of a piece of pipe with spindles hammereed into it, no springs. There is a coment below the build plans that says it tracks well at 65mph with a 1 Ton load on it.
dh
Postby doug hodder » Sat Apr 10, 2010 11:45 pm
There weren't as many lawyers then either..... :lol: Doug
Users browsing this forum: Google [Bot] and 0 guests
