HF wiring harness
Anything electric, AC or DC
Postby steve smoot » Tue May 04, 2010 1:47 pm
Hi everyone,
Well, I finally got time to work on the lights again. I ran a ground wire to each fixture, as some of you have done, and I am happy to report that all lights are now working... :applause:
I am not a complete idiot, some parts are missing...
steve smoot
Images: 62
Postby absolutsnwbrdr » Tue May 04, 2010 1:55 pm
Good to hear!
Zach
Coming Soon...
absolutsnwbrdr
Images: 412
Postby ARKPAT » Fri May 07, 2010 11:13 am
I had the same problem with my HF trailer and a warning ticket for the lights that some times worked. So I wired the lights with a ground wire to each light and replaced all the lights with LED ones.
:cry:
Pat
Life is to short always eat dessert first.
ARKPAT
Images: 77
Postby len19070 » Fri May 07, 2010 5:32 pm
steve smoot wrote:Hi everyone,
You are so much better off this way.
Almost every automotive light made uses a common ground and If it weren't on a "Moving Object" I would say its fine.
And a lot of times it is fine but all it takes is a little "jiggling" some rust or a loose bolt somewhere, somewhere is a BIG word.
And you've got to start with "Adam & Eve" and work your way up to find the problem.
2 wires, one to a hot and the other to the Battery AND the frame isn't hard to trace.
But one hot and the other to a bolt on the light, that's connected to the fender, that's connected to a bracket, that's connected to the frame and the frame is a "Bolt together" and then to the tongue and bla bla bla and on and on.
I spend a lot of time at gatherings under trailers finding ground problems.
Smart move.
Happy Trails
Len
len19070
Images: 24
Postby Grid Runner Adventures » Fri May 07, 2010 10:38 pm
I need to replace the harbor freight wiring harness on mine. its been about 4 years that I've had it and back and forth between wisconsin and washington state several times.
www.offgridrving.com
Follow my build of a off grid camper that is 6x8 and I will live in it for an entire year!
Google Is My College
Postby toypusher » Sat May 08, 2010 6:02 am
Have used my HF for over 5 years with no problems! My ground is to the frame as per directions that came with the trailer.
toypusher
Images: 324
Postby Arne » Sat May 08, 2010 7:24 am
both of my h/f frames were welded.. never had to run a ground to each light over 6 year... but, if that is what it takes, that is what you have to do.
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby Senior Ninja » Sun May 09, 2010 10:33 pm
When I bought my HF trailer I also picked up a bag containing two pieces of that plastic armor for wiring. It just happened to be the right length. I feel better know the wiring is protected from rubbing on the frame members.
Building the TD was the best thing I ever made.
Senior Ninja
Return to Electrical Secrets
