Wes' teardrop - Fiberglass finished Bondo started - Page 9
Postby starleen2 » Sat May 01, 2010 9:28 pm
It ain't goinin' nowhere Wes - you might want to run a few staples down the seams
starleen2
5th Teardrop Club
Postby WesGrimes » Sat May 01, 2010 9:34 pm
The staples are a good idea. I was also thinking about putting JB Weld on all the seams, but that is probably going to be $30 worth of JB Weld, and I am not sure it is needed...
Yours looks great by the way!
WesGrimes
Images: 31
Postby WesGrimes » Sun May 02, 2010 8:54 pm
I finished coating the bottom with contact cemented galvanized flashing and JB Welded and caulked the seams.
I then mounted the board on the frame and glued down the linoleum.
It is starting to feel like it just might be a camper one day :D
WesGrimes
Images: 31
Postby WesGrimes » Sat May 08, 2010 12:15 pm
With a little help from John (JSS06), we got the cabin mounted on the trailer frame! Thanks John!
WesGrimes
Images: 31
Postby parnold » Sat May 08, 2010 12:31 pm
Sweet!
:applause: :applause:
parnold
Images: 302
Postby 2bits » Tue May 11, 2010 10:39 pm
Oh yeah! Now it is looking like a teardrop when you can see the wheels! It is the same thing but man, it looks different somehow! It has a feeling of motion to it. Good job on the profile! I wish I coulda been there for the barn raising!
Thomas
2bits
2bit Member
Postby WesGrimes » Tue May 11, 2010 11:13 pm
Thanks Thomas,
I kinda wished I had not gone flat on the roof like I did. I did it for interior space, but I really prefer the continuous curve like your roof profile has.
I think I have spent too much time staring at all of the lines and over analyzing everything though. It will look good when the paint is on I think.
WesGrimes
Images: 31
Postby 2bits » Tue May 11, 2010 11:19 pm
When I look at it, I do not see a flat spot although I know it is there if that helps!
Thomas
2bits
2bit Member
Postby glassice » Tue May 11, 2010 11:33 pm
Man that is to bad look like you have a buck there
It is not the return ON my investment that I am concerned about; it is the return OF my investment
glassice
Postby starleen2 » Wed May 12, 2010 7:44 am
That flat roof ain't gonna make a bit -o- difference due to the cool radius on the edges once it glassed! :D
starleen2
5th Teardrop Club
Postby aggie79 » Wed May 12, 2010 8:29 am
:thumbsup: Looking good Wes.
Postby WesGrimes » Wed May 12, 2010 1:41 pm
glassice wrote:Man that is to bad look like you have a buck there
Hi Glassice,
I am not sure I understand. Are you saying that I have a buckle in something?
Thanks,
Wes
Edit - Actually, I think I know what you are talking about. Right above the wheel there is a row of knots in my plywood that run from top to bottom. It kind of looks in the pictures like it might be buckled there. Fortunatly that is not the case. It is flat and straight from front to back.
WesGrimes
Images: 31
Postby WesGrimes » Wed May 12, 2010 1:42 pm
Thanks all!
WesGrimes
Images: 31
Postby glassice » Wed May 12, 2010 2:09 pm
No looks great you where going to pull a mold off of it at 1 time you have done a great job no undercut good clean lines look like you where almost there
glassice
Postby grizz » Wed May 12, 2010 3:54 pm
Approved. 8)
Greetings from England.
Rian.
grizz
Images: 29
