T-49 - Temporary .5 Teardrop Wagon - Camping Pics - Pg 8
Postby bobhenry » Thu Jul 08, 2010 3:03 pm
teardrop_focus wrote:
Ever try to dado a 10 ft piece-O-ply? ...on a small router table?
:SH
For a spline joint ??
If ya set a biscuit cutter for the proper drop to center the shove it in and drag it will cut a great spline cut then just fabricate a spline to fit and glue it in ! :D
Postby doug hodder » Thu Jul 08, 2010 9:00 pm
Bob Henry has the ticket...or when the work is too big for the tool, bring the tool to the work....use a piece of material as a fence, clamp it and use the router to cut your rabbet. Doug
Postby teardrop_focus » Thu Jul 08, 2010 9:18 pm
Hey fellas! Coffee break.
No.
I'm working w/ 4 X 10 ply... and all the dados have been cut. What happened is that I spied a router table on my neighbor's table saw... so we tried to rout the 10' section that way. Next time with stuff that big like Doug says I'll bring the tool to the work instead of the other way around. I clamped various fences over the rest of the work to carve the other, shorter dados and rabbets.
Now, if I'd done this sort of thing before, it'd be going a lot faster!
:lol:
...but all that's left now are two rabbets on the front and rear of the trailer floor... both 3/16 deep, one 1/4" wide, the other 1/2" wide like what I just did on the walls this afternoon. Pics later tonight.
Now it's back out to the stall to bolt the supension back on then bolt the ply floor onto the chassis to make it as straight as possible so that the dado'd sides will slip onto the floor.
But first I'll mark and drill pilot holes for the 4" shedule for the woodscrews when gluing tomorrow afternoon.
:hammer:
teardrop_focus
Images: 127
Postby Wolfgang92025 » Thu Jul 08, 2010 11:20 pm
Chris,
I know your feeling, too much work and not enough time.
Hang in there and well see you at IRG III.
When do you plan on leaving LA ?
Wolfgang
Wolfgang
Wolfgang92025
Images: 660
Postby teardrop_focus » Fri Jul 09, 2010 12:56 am
Gracias, Volfie...
Planning on leaving El Lay Tues morning...
:thinking:
We'll see.
teardrop_focus
Images: 127
Postby 2bits » Fri Jul 09, 2010 1:12 am
Since this is a temporary structure knock it out and don't forget to slap a little stain on that wood!
Thomas
2bits
2bit Member
Postby teardrop_focus » Fri Jul 09, 2010 1:43 am
You're a man of few words, lately, Thomas... :roll: ...however, I always like it when you pop in and say anything. :D :yes:
I can't just knock it out as I wanted to; I have a standard of precision... whether or not I actually achieve that standard is another story.
:lol:
As for the stain idea, the "good" side will be the interior facing and wiped w/ Feed-N-Wax, an orange-oil/beeswax emollient; the knots' side/exterior will be painted dark red. A tan-colored tarp will cover the open top.
Here're some pics from this afternoon's hacking:
I also torqued the half-axles to their mountings w/ fresh locknuts; previously they were simple bolts to facilitate quick disassembly.
Then a couple of old buddies stopped by for a look; they helped me fish the jacketed 7-wire trailer chassis wiring cable through the tongue and crossmember. Pics of that, tomorrow.
Thanks again for lookin in!
8)
teardrop_focus
Images: 127
Postby bobhenry » Fri Jul 09, 2010 6:52 am
OH ! That dado :oops:
A picture IS worth a thousand words !
I was way off beam ( as usual)
Nice work !
Postby 2bits » Fri Jul 09, 2010 7:30 pm
Yeah, these days I am scrambling to just get on the board and pop in to see what's up! I remember the old days I could spend hours. I am not working on the teardrop hardly at all now, but I have less time! What's up wit that!
Thomas
2bits
2bit Member
Postby teardrop_focus » Sun Jul 11, 2010 5:39 am
Thanks, Bob. :lol:
Thomas, thanks always for dropping by. :shake hands:
I ran out of steam too early Friday evening but kept at it. Then I didn't want to get out of bed Saturday morning, but I have a deadline and this thing won't build itself.
:SH
My next-door neighbor Bob came over to help with the tough job of getting the now-bowed 3/4 ply floor into the wall dados. He glued then held the wall while I drilled then screwed them onto the sides of the floor.
As I post this it's the middle of the night and I can't sleep. Think it might have been the big ol' mug of coffee I had at 7:30 PM?...
So here're some pics:
Walls up -
Don't let your ply floor sit around for too long if not layed flat on the ground. This ACX began to bow, which made our job a little difficult...
On the ground - (that headboard curve just kinda happened. The piece was too tall and we talked about best sealing the front of the tarp for travelling, so here we are, with this...)
Next is a piece of 1/4" ply for the rear wall, chassis wiring and some paint.
Okay, I'm going back to bed.
:SH
teardrop_focus
Images: 127
Postby Nathan N » Sun Jul 11, 2010 6:33 am
Wow. I love the design contours you are coming up with. I'm anxious to watch the teardrop body come to life. Great job!
Nathan N
Images: 153
Postby Rigsby » Sun Jul 11, 2010 9:07 am
That is one hell of a sexy trailer :applause:
DOOIN IT THE YAARKSHA WAY--FA NOWT, THA NUS !!
Rigsby
Postby 2bits » Sun Jul 11, 2010 9:48 am
You are taking build the first one and throw it away concert too far by actually planning to do that! LOL That actually looks pretty coo tho!~
Thomas
2bits
2bit Member
Postby mandy » Wed Jul 14, 2010 1:20 pm
Hey Chris I hope your having fun at the IRG. :thumbsup:
~Plato~
mandy
Images: 86
Postby grizz » Thu Jul 15, 2010 2:16 pm
I LIKE IT, I LIKE IT , I LIKE IT !!!!
Looks great Chris.
Greetings from England.
Rian.
grizz
Images: 29
