Terry's TTT Garageable Standy Build modifications
Postby terryjones1 » Wed Dec 29, 2010 11:53 am
Shown below is a trial fitting of the wheel well/fenders. The assembly of the fenders are using temporary screws. The plywood parts will be permanently assembled with epoxy & 1-1/2" #8 screws.
Tomorrow, December 30, 2010, we leave on a 15 day cruise from LA to Fort Lauderdale through the Panama Canal. I , of course, will not be working on the trailer.
My TTT Garageable Standy Build Journal: viewtopic.php?f=50&t=40591
terryjones1
Postby StPatron » Wed Dec 29, 2010 12:29 pm
Looking good, Terry. :applause:
I like how you've done the wheel wells, lot of work there. I used a combination of spray undercoating and roofing tar on mine, quick and easy.
Have fun on your cruise. 8)
StPatron
Images: 297
Postby lstyles » Mon Jan 17, 2011 2:53 pm
HI Terry,
Any updates. I am watching your build closely as I am considering something really close to this.
thanks,
Lori
lstyles
Postby bdosborn » Mon Jan 17, 2011 9:53 pm
Yeah, hurry up and post some pictures...
:thumbsup: :thumbsup:
Images: 778
Postby S. Heisley » Mon Jan 17, 2011 10:45 pm
Hey, guys, they would have just gotten back. If you see any pictures tonight, it'll probably be from the cruise.
Postby terryjones1 » Wed Jan 19, 2011 8:42 am
We are back from the cruise. I now have some weight to loose.
Mondy, I ordered another batch of Epoxy from Raka. This epoxy will be used mostly as a glue for the sidewall plywood & wood sidewall frame.
Today, I will be purchasing 3 sheets of 1/2" particle board. These will be placed on the trailer to make up a large work table.
I will, also, purchase 4 sheets of 3/16" "hardboard". These will be used to make paterns for the trailer side walls.
At Lowes', they have 1/4" Aracuo hardwood ACX plywood, with 3 ply, and exterior glue. ($22.97 ea) It looks pretty good, and is paintable without showing the wood grain. It looks like I will buy 24 sheets. (I will have a lot of waste)
I will, also, buy 1" x ?" pine for framing. I will rip down to 1" (actual) width.
Pictures will follow.
terryjones1
Postby terryjones1 » Thu Jan 20, 2011 12:47 pm
Yesterday, I picked up the Hardboard, the particle board, & the 1/4" Aracuo ACX plywood. The plywood was a full 1/4".
This morning I drug out the table saw.
I will pick up lots of 1 x ? lumber this morning. I will buy mostly clear dryed lumber. This will, of course, be used for making the wood frame for the trailer.
The first thing that I will do is rip the 1 (3/4" actual) x to 1" wide.
terryjones1
Postby terryjones1 » Mon Jan 24, 2011 7:13 pm
I have layed the 1/2" particle board on top of the trailer frame to make a large layout table as shown below. I have placed the 3/16 hardboard on the layout table. the hardboard will be used to make a patern for the trailer sides.
I purchased 2 sheets of 1/4" (more like 3/16") mahogany "bendy" plywood. It will very easily bend to a 10" radius. See below. I will be using a 15" radius.
terryjones1
Postby terryjones1 » Tue Jan 25, 2011 2:30 pm
I have designed the roof line to have a 4" drop from center of trailer (the horizontal measurement is 61") to the start of a 14-3/4" radius curve at the front and back of the trailer roof. I used a CAD program (Design CAD) to calculate the curvature using three points (4" drop from start of radius at front , center, 4" drop from start of radius at rear). I calculated serveral heights of the curve from a 4" x 61" triangle. I then laid out my calculations on 3/16" hardboard. Since the front roof line is the same curve as the back roof line, I have made one template 61" in length. I will, of course, reverse the template to make the back curvature. Shown below is the template that I am in the process of sanding the edges to the curve. I have also made a 14-3/4" radius quarter circle template. I will mate this with my roof line to have a complete template for the sidewall, including front and back 14-3/4" radius curves, at the roof line
terryjones1
Postby terryjones1 » Tue Jan 25, 2011 5:07 pm
Shown below is template of sidewall roof line. The length is 1/2 the length of the trailer. The curve template was not as complecated as I thought it would be. I used a router to cut the 14-3/4" 1/4 circle.
terryjones1
Postby terryjones1 » Wed Jan 26, 2011 7:53 pm
Shown below is the profile that I have decided on.
terryjones1
Postby StPatron » Wed Jan 26, 2011 8:52 pm
Lookin' good! :thumbsup:
Thanks for all the pictures.
StPatron
Images: 297
Postby droid_ca » Wed Jan 26, 2011 11:20 pm
I like your use of the templates
good job keep up the excellent work
“Fide Canem”
viewtopic.php?f=5&t=52816
droid_ca
Images: 176
Postby terryjones1 » Sun Feb 06, 2011 1:59 pm
I am planning on Prefabricating the outside walls, (1/4" inside & outside plywood walls + 3/4" framing) glued with epoxy.
I plan on using 1-1/2" x 1-1/2" x 1/8" angle steel, 1/4" bolts, nuts, & washers, and 1/4" screws to attach the walls to the floor & frame.
Where their is steel frame below, I will use screws through the angle steel.
Where there is 1/2" plywood, I will use bolts, nuts, & washers through the angle steel.
I will use screws to attach the walls to side of frame.
I will use bolts, nuts, & washers to attach walls to angle steel.
Considering my trailer will be near 7 feet high from the ground, and over 12 feet long, does anyone have any concerns with my plan for attaching the walls?
Sorry about the extremely small drawing.
terryjones1
Postby bdosborn » Sun Feb 06, 2011 2:17 pm
That's about what I did on mine only I used 1/8" ply for the interior skin and kreg pocket screws instead of the angle plate. I used long pocket screws to make sure I got a good bite into the floor framing. I used a screw about every foot or so and my walls are very solid. I glued the wall to the floor and I think most of the strength is from the glue with the screws acting as backup to the glue.
Images: 778
Users browsing this forum: No registered users and 24 guests
