reversing tongue on HF trailer
Postby kzhorse » Sun Jul 24, 2011 11:51 am
The way I am built I have a little to much toung weight should I have any problems with the axle pulling it backwards? I dont have any room to move the axle forward without getting into the door.
Scott
kzhorse
Postby angib » Sun Jul 24, 2011 1:12 pm
Do you mean to remove the tongue from one end of the HF trailer and fix it to the other end, so the trailer is the other way round?
If so, and you have too much tongue weight now, you'll get negative tongue weight with the trailer the other way round and that's a recipe for disaster when towing.
But can an axle be used backwards? - no problem, as long as it doesn't have brakes.
angib
5000 Club
5000 Club
Images: 231
Postby kzhorse » Sun Jul 24, 2011 1:37 pm
Thanks for the reply,I figured it would not be that easy.I guess I will just have to load the rear when towing.
Scott
kzhorse
Postby eamarquardt » Sun Jul 24, 2011 3:10 pm
Moving the axle aft is just going to increase your tongue weight. An option might be to rearrange the stuff inside your trailer while towing to get a tongue weight within reason.
A couple of questions come to mind.
What is the capacity of your vehicle as far as tongue weight goes. Is your tongue flexing at all or does it seem OK.
There is really nothing wrong with going with a higher than "rule of thumb" tongue weight as long as you don't exceed the strength of your tongue or the capacity of your hitch.
Cheers,
Gus
eamarquardt
Images: 150
Postby bobhenry » Mon Jul 25, 2011 6:25 am
Get it towing level ! You have all the weight tipped forward. If you have a receiver type hitch get an up sweep ball mount. If you weigh it with this tongue height and weigh it again level you will see a hugh difference in the tongue weight.
Postby Dale M. » Mon Jul 25, 2011 9:11 am
Tongue weight???....... First off have you put tongue on scales....
Car seems to be sitting level in pictures and angle on trailer indicates hitch on car is to low....
Also the way coupler is on tongue looks funky like its to high or mounted wrong... Got a detailed picture (close up)...
Need additional information....
Dale
Dale M.
Images: 18
Postby bobhenry » Mon Jul 25, 2011 9:31 am
Looks like the standard HF coupler mounting.
This mod will get you a couples inches up and improve towing and backing by extending the tongue a bit.
http://www.tnttt.com/viewtopic.php?t=42166&start=0
Postby kzhorse » Mon Jul 25, 2011 11:53 am
bobhenry,Thanks for the link I will pick up a piece of 2"x2" from work and get this done before I take it out again.The first trip out was this weekend went to Gettysburg and every thing went good.I will have to replace the pins with bolts,I didnt like the bumping noise over bumps.
Scott
kzhorse
Postby legojenn » Mon Jul 25, 2011 12:21 pm
If you flip the tongue, I would suggest flip the wheels so they roll in the correct direction too.
Jenn
legojenn
Postby absolutsnwbrdr » Mon Jul 25, 2011 12:40 pm
legojenn wrote:If you flip the tongue, I would suggest flip the wheels so they roll in the correct direction too.
:lol:
Zach
Coming Soon...
absolutsnwbrdr
Images: 412
Postby bobhenry » Mon Jul 25, 2011 1:10 pm
You don't flip anything but the little plate that the coupler sets on. simply un bolt the coupler plate and turn it over then slide the 2x2 thru to as far as you feel good about going. I took mine all the way to the rear and used the back end for a 1 1/4 draw bar receiver. My trailers are extended to 10' bodies so if I remember correct my 2x2 was 13' - 14' and extended my stock tongue forward 18"
here is the rear "receiver" on my barn
Then you CAN take it with you
state laws permitting !
Just goes to show ya'!
Postby bearfromobx » Thu Sep 15, 2011 7:11 pm
Bobhenry proves a TTT'er CAN take it all with him! House, barn and truck, all in one load! :)
Just an overeducated Redneck with a love of learnin' ...
bearfromobx
Postby madjack » Thu Sep 15, 2011 8:46 pm
I tried reversing my tongue once...all it did was tickle the back of my throat...and evetime I went to swallow, it trickled down my chin :o :thinking: :roll: ;)
madjack 8)
p.s. sorry, sometimes I just can't help myself :R ....................mj
Postby satch » Thu Sep 15, 2011 10:37 pm
madjack wrote:I tried reversing my tongue once...all it did was tickle the back of my throat...and evetime I went to swallow, it trickled down my chin :o :thinking: :roll: ;)
madjack 8)
:lol:
Only MJ can get away with that one!
If it itches. scratch it
Rick
satch
Images: 63
Lord, save me from this PUNishment!
Postby bearfromobx » Sun Sep 18, 2011 9:10 am
:lol:
bearfromobx
