Postby eaglesdare » Thu Jan 19, 2012 10:18 am
i bet. i am not finding anything cheap yet.
Louella
May the foam be with you.
eaglesdare
Postby Wolffarmer » Thu Jan 19, 2012 11:02 am
GPW wrote:Eagle , this drawing did it for me ...
A good ole sheep camp. Though the classic sheep camp was built on 4 wheels. At the corners. Was usually built on a salvaged wagon and then later some kind of worn out pickup/car. And having four wheels in the corners made so you didn't have to use jacks. And the classics used a canvas top. I see now that the new ones are built on a 4 wheel trailer chassis. I have never stayed in one but in my youth I did visit several and had a few excellent meals.
Randy
Wolffarmer
Images: 309
Postby linuxmanxxx » Thu Jan 19, 2012 12:50 pm
Eagle a word of caution with your plans is weight......you are looking at a bigger heavier trailer and then the couches/dinettes/slideouts and other things require wood framing and wood thus weight and towing issues.....you might have to get a little beefier TV for going biggie foamy.
linuxmanxxx
Images: 10
Postby eaglesdare » Thu Jan 19, 2012 1:06 pm
thanks linux. i can always have fun doing a new one and letting the old man have it. :lol: maybe i can con him into getting me a new tv?
Louella
eaglesdare
Postby linuxmanxxx » Thu Jan 19, 2012 1:21 pm
If you get something with a V6 at least in it your tow ratings will go way up and still keep a decent amount of economy as well. Ford's new ecoboost stuff is really looking good for power and economy even the 4 cylinder is putting up crazy numbers. The full size 4 dr F150 supercrew with ecoboost V6 gets 23 mpg on highway (yeah that big truck) I have an 01 supercrew and it drives like a car and still is a truck love it.
And remember Ford was the only non bailout american car company.
linuxmanxxx
Images: 10
Postby eaglesdare » Fri Jan 20, 2012 8:44 am
well since its been pretty quiet here, i will update simba. he is 5 months old now.
Louella
eaglesdare
Postby GPW » Fri Jan 20, 2012 9:49 am
Whoa !!! :o Looking around at box trailer prices ... They do seem Pricy... :shock: Most well over 1K ... and UP ... waaaay up ... Like Steve said , requiring a larger truck ... I even saw one yesterday right down my road that has 6 wheels (BIG) ... :o
Maybe need to set a target weight , including the trailer , and try to build to that ... the trick is to weigh everything ... before you put it on ... ;)
Just more thinking that many things on the inside that are done with wood , could be lightened a lot by using the “sandwichâ€
Postby GPW » Fri Jan 20, 2012 9:51 am
What a CUTE Dog !!!! :thumbsup: 8) :D
Postby eaglesdare » Fri Jan 20, 2012 10:02 am
yes very pricey! i will take a ride around next friday or saturday and see what we have locally.
and i do understand weight issues.
Louella
eaglesdare
Postby droid_ca » Fri Jan 20, 2012 10:15 am
GPW said-would not only have a utilitarian function , but also may serve as internal “bracingâ€
“Fide Canem”
viewtopic.php?f=5&t=52816
droid_ca
Images: 176
Postby eaglesdare » Fri Jan 20, 2012 10:23 am
i had to go a looking. is that a boxer? or a mastiff? looks like a boxer from what i can see. find looking dog!
Louella
eaglesdare
Postby droid_ca » Fri Jan 20, 2012 10:35 am
They both are boxers I started initially with the one and then saw the male as well .....So now I have to put my trailer on hold yet again...but thats why we are here
“Fide Canem”
droid_ca
Images: 176
Postby atahoekid » Fri Jan 20, 2012 11:35 am
I agree with the sandwich construction method. I built my cabinets, bulkheads, shelving with the thought of bracing the structure so that goal is the same, but in retrospect and if I were to do it over again,instead of using 1/2" plywood, I would go with the sandwich construction. You may gain a bit in thickness by going that way but the end goals of bracing and creating useable space remain the same. The vacuum bagging technique would be awesome for creating the sandwich. I wish I had asked more about that when I was in my planning phase, but it's not too late to use it to put the inside layer of lauan on the walls and ceiling. Just need to find a valve and buy plastic sheeting. :thumbsup: :thumbsup:
Mel
atahoekid
Images: 158
Postby GPW » Fri Jan 20, 2012 12:28 pm
When I was covering my inside panels with old bed sheet , I found that alone made the foam extremely stiff... and we could build cabinets and shelves like this that would span the structure and provide “inside bracing “ and it wouldn’t need almost any wood at all ... maybe a little for “trimâ€
Postby atahoekid » Fri Jan 20, 2012 2:27 pm
I guess this falls into the category of "build it the way you want it". I just like the look of the wood interior and yes, wood (even thin lauan) weighs more than canvas, but I was never hugely concerned about the weight since my TV is big enough and the frame is strong enough so in this case, form won out over function.
GPW is right... so many possibilities :thumbsup: :applause: :thumbsup: :applause:
Mel
atahoekid
Images: 158
Users browsing this forum: Google [Bot] and 8 guests
