It's been a beautiful norcal winter for working on the teardrop trailer, mostly. Not this week though. This week, while I was on spring break, and could have spent most days working on the trailer from morning 'till night, it rained with typical pacific northwest coastal storm intensity. As someone noted up thread, my shop is virtually outdoors, being just two 10 x 20 carport tents strapped together. There is a gutter between them, but it's an imperfect solution at best, and runs over copiously when it rains hard. It pounded rain most of this week. It's not a pleasant environment to work in when it's storming, both because of the wet and the noise. Hard rain on that plastic sheet roof is NOISY!
Case in point. Yes, that's a stepping stone. Does your workshop have stepping stones over the deep mud holes? I thought not.
Poodle bites, poodle chews it. I wonder if anyone will recognize THAT?! Anyway, more mud and dripping ceilings. The power tools and the trailer have so far kept dry. That wet spot in the center is precisely where I had to stand to cut up the half inch baltic birch sheet for the galley drawer boxes. It was great fun balancing a 5 x 5 sheet on that contractor's saw with water running down my face and neck....
Despite the wet conditions, I managed to insulate and skin the galley side of the rear bulkhead. The seams will all be concealed later, and in fact the skin was probably unnecessary since it'll mostly be covered by other stuff, but this way I know the rear bulkhead insulation is secure and sealed.
Here is a set of drawer boxes in progress for the galley. My galley is going to be quite different from the Kuffel Creek specs, both because we wanted to build things a bit differently and because we have to-- our trailer has MUCH higher ground clearance than the specs, and that would put the galley counter up around chest level. Not good. So we're winging it. Drawer boxes:
Adding maple face frames to the drawer boxes:
I also milled out a top shelf for the front cabin headboard/closet, shown here, with beveled-to-fit back edge, crown molding front profile, and a dado to capture the face frames. One hundred percent table saw work. The rest is in various stages of finish. Soon, grasshopper, I shall glue that all up to the sub-frame and mount the doors, which are made and ready to go. They're frame and panel maple to match the center panel. We'll mount an electronics console above the top shelf, primarily to supply reading lights but also some other stuff. There's still a lot of interior work to go.
Here's the cherry top shelf, wetted out with mineral spirits. It's a beautiful piece of wood, with tan, brown, pink, orange, and olive green grain swirls. This photo doesn't do it justice. I'm an utter wood slut. Beautiful grain and figure makes my knees weak.
Who puts stuff like this into a CAMPER, for cryin' out loud?
I also got the 12v panel built and ready to wire, along with a few other electrical chores. I'll show pics of those in a later update. Oh, and I graded a hundred or so midterm exams in Zoology, with some very much appreciated help from Kathy on the multiple choice bits ( and she also helped me cut the crown molding profile on the front edge of the headboard top shelf, which definitely needed a second set of hands without a level outfeed table). Thank you, sweetie!
Thanks for watching. More to come.
--Mike C.
If it isn't broke, perhaps a more expensive tool is required to break it....
