Well, couldnt not try to make it fit, after all I have a working gas fridge.
So I attacked it today
Knocked down the sort-o-cabinet
and It sets in there nice
Cut back the foam, I sort of remembered there was wire buried in this section of wall....Yuppers
Got it cut out, wires and water lines protected and cabinet built and sealed to the inside
Fridge cabinet insulated with 1 1/2" foil backed foam
Access door vent installed on the outside
Fridge in, counter in
Just have to run propane line and source a top wall vent for the fridge
And seeing as it is a holiday, I couldn't finish the cabinet under the overhang cause the stores are closed
Fridge has a flint spark ignition, I tore it all apart last night cause it was seized, drilled out the stuck flint, cleaned it all up, new flint and it works
Only have about 9 inches of counter on the overhange, Need to try and get a sink in somewhere for washing up
Don't want to go vessel sink on top of counter, cause I hate them, but may have to
Do they make 9 inch wide bar sinks that don't cost $700, sheesh
Wonder how much more I can stuff in a 6' 6" x 9' 6" box ????
