Cutting Symmetrical Side Walls
Postby shootr » Mon Jul 02, 2012 6:11 pm
As I plan my 4' x 8' Benroy-style trailer build on a Harbor Freight frame, I'm taking into account my limitations in skills for fabricating things. Currently I'm preparing to create the sidewalls out of 1/4" ply/1" rigid foam/1/4" ply sandwich/composite construction, with solid wood framing inside for structural support.
I know for a fact I will never cut 4 sheets of plywood separately and maintain the same profile on all of them. I haven't seen it mentioned anywhere so far, but is it feasible to expect I can clamp/screw all 4 sheets of 1/4" plywood together, draw out the profile, and cut them all at once? Or was it a given that is how it is done anyways.
Thank you.
shootr
Re: Cutting Symmetrical Side Walls
Postby Woodbutcher » Mon Jul 02, 2012 7:25 pm
I would suggest making the inner frame work first. Match both to each other. Then attach your skins and trim off the excess with a flush bit (with bearing) in your router. It is easier to use 3/4" plywood for the sides. Much less work and after you make 1 piece to your profile you can match the other using the flush bit. Just a thought.
Woodbutcher
Postby Loader » Mon Jul 02, 2012 8:10 pm
That is exactly what I did, stacked all four pieces ensuring proper orientation (interior face vs exterior face) and cut! A bit scary at first, but slow and steady with a sharp blade. I cut a little proud of my mark, and then sanded them flush to the line. I have used that technique on two builds with decent results.
Some people have made templates a have had great results. Trim bits and a router also can be your friend!
Good luck in what ever method you choose.
Earl & Kerry
"Loader"
Loader
Images: 245
Postby Lgboro » Mon Jul 02, 2012 10:11 pm
I just bent a piece of 1/4 inch molding to the shape I wanted and traced it. I stick built out of cedar for weight savings. Also cedar stripped the inside with sub 1/8" cedar strips and no outside wood just floated aluminum. Haven't installed my pet cool so I haven't weighed yet but it is really light to have TV,radio, solar, etc. and other goods installed. A lot of work but I tow with a Jetta so to me it was worth the extra time and work.
Lgboro
Images: 53
Postby asianflava » Mon Jul 02, 2012 10:57 pm
I made a template out of 1/4in ply and used router to cut my "stud walls" and the faces. I think 1/2in for the template would be better since it gives the router bearing more surface to ride on, but it will be heavier and harder to handle. IMHO 1/4in with 1in foam is pretty thick, especially for a 4x8. I used 1/8in luan for the faces and 3/4in foam in the walls.
asianflava
Postby aggie79 » Tue Jul 03, 2012 9:52 am
asianflava wrote:I made a template out of 1/4in ply and used router to cut my "stud walls" and the faces. I think 1/2in for the template would be better since it gives the router bearing more surface to ride on, but it will be heavier and harder to handle. IMHO 1/4in with 1in foam is pretty thick, especially for a 4x8. I used 1/8in luan for the faces and 3/4in foam in the walls.
If possible purchase or borrow a router and template bit.
Like others, I made a template out of 1/4" MDF. (In the picture I had not yet cut the door opening in the template.)
44730
For "framing" I used 3/4" plywood. Lay the template on top of the plywood and trace the outline of the framing onto the plywood.
44904
Then remove the template and rough cut the plywood framing with a jig saw.
44901
I don't have a picture of it, but place the template back on the plywood, and use a router with a template bit to finish cutting the plywood framing. (I purposely did not cut the doors all of the way through at this time. I left the door framing in place so that the grain of my interior finishes would be continous.)
46030
As others have said, 1/4" plywood will work as exterior and interior skins but 1/8" plywood will be strong enough and will save some weight.
Postby markhusbands » Wed Jul 04, 2012 1:08 pm
couldn't you do the routed plywood frame concept and just skip the MDF template, using the first plywood frame as the template for the other frame and the four skins?
133923
markhusbands
Images: 58
Postby Verna » Wed Jul 04, 2012 4:47 pm
markhusbands wrote:couldn't you do the routed plywood frame concept and just skip the MDF template, using the first plywood frame as the template for the other frame and the four skins?
The MDF is less expensive than the plywood. So many of those building the tear drops see "things" they want to change after making the template. Since MDF is cheaper, it's not as great a loss if the changes are so great that another MDF template needs to be made.
Verna
Indianapolis, IN
Verna
Images: 49
Postby aggie79 » Wed Jul 04, 2012 5:54 pm
The 4' x 10' x 1/4" was $11 so if I messed it up I wouldn't be out much money. Another reason to use a template rather than just cutting the plywood is that I re-used the template many times to cut my roof framing, hatch framing; align the dado joints for my front cabinet and bulkhead face frames; cutting the aluminum for my sidewalls, etc.
Postby markhusbands » Thu Jul 05, 2012 11:43 am
I'm convinced. The MDF template seems really useful.
Here's another question. Let's say you want to build somewhat taller walls - perhaps a bit over 5'. Would you consider it crazy to build the wall cores in front and back halves (using the routed foam-filled approach) and then skinning with thin ply in top/bottom halves?
And would you skin them flat (easier to manage glues) then erect, or upright (smaller, lighter pieces to pick up) and then skin?
133923
markhusbands
Images: 58
Postby Fishingtomatoseed » Thu Jul 05, 2012 11:56 am
Woodbutcher wrote:I would suggest making the inner frame work first. Match both to each other. Then attach your skins and trim off the excess with a flush bit (with bearing) in your router. It is easier to use 3/4" plywood for the sides. Much less work and after you make 1 piece to your profile you can match the other using the flush bit. Just a thought.
What woodbutcher said.
Worked good for me.
Fishingtomatoseed
Images: 9
Postby NathanL » Thu Jul 05, 2012 4:18 pm
Lot of good techniques but I will say even if you don't get it quite the same you won't notice unless you make one side 6" shorter than the other, or nearly that much.
Go measure car doors on a cars made in the 50's and earlier, even on a car like the '55 Chevy the door lenghts aren't the same with one side being 1/2 longer than the other because the tooling was made from a handmade model.
It's amazing the stuff I have measured that looked "dead on" that was so far out of square and plumb it wasn't funny.
NathanL
Postby shootr » Thu Jul 05, 2012 4:56 pm
Couple things:
If I'm using composite construction (thin ply/foam/thin ply with solid wood inserts at key points), I'm not seeing how the flush bit thing works. I want to build insulated because of the temp extremes I intend to use it in - +100degrees summertime and freezing temps in the fall/spring. Is it the consensus that insulated isn't necc.? (I'm not installing heat or AC, our tents never had them and I don't want the hassle/noise/etc. - I'm supposed to be camping! :)
When people are saying they are using 3/4" ply and skinning it - do you mean 3/4" "ugly" plywood, and a "beauty" skin of luan for looks, with no insulation?
I really appreciate everybody's input - this forum is the most enjoyable I've been on (in any topic)! Thank you all for taking the time to write back. :beer:
shootr
Postby shootr » Thu Jul 05, 2012 4:59 pm
NathanL wrote:Lot of good techniques but I will say even if you don't get it quite the same you won't notice unless you make one side 6" shorter than the other, or nearly that much.
I'm pretty OCD, so I've been figuring on fairly tight tolerances. My nightmare is trying to sheet the roof, but because the sides aren't plumb to each other, the roof sheet won't lay flat and show ripples or buckles or whatever...
shootr
Postby asianflava » Thu Jul 05, 2012 7:37 pm
shootr wrote:Couple things:
Like this?
Like I said, you don't need walls that thick, 1/8in luan is all you need for the faces. The whole reason to put the "studs" in the walls is the same for a house, so you can screw things to solid wood.
In this picture the template is on top, screwed down to the frame. The router bearing rides on the template and the flush bit cuts the wood underneath.
asianflava
